the abs light & tcs button was coming on & off yesterday a few times, then 30 mins later driving i seen smoke from the front.
the front passenger brake seemed seized to me cause it was pulling to the right after i tried to drive.
i then went to a local shop not dealer so i could see what it is he said its not locked up i can turn the wheel, but the clapier,brake pad, rotor took a beating.
i asked him to scan it for codes this is what we got:
I think it has been sitting a bit and the calipers or slide pins seized. That actually is fairly common for those that don't put alot of miles on them.
I drive the truck everyday, I can understand if its been sitting for awhile but I guess to be on the safe side I should take it in to the ford dealer to ensure its all safe.
I hope they just say what you said about just doing a brake job then replacing any big parts!
The brake did squeak when I pressed the brake even today so hopefully it's just a simple brake job.
