starting problems '04 6.0
Old Jan 21, 2013 | 01:17 PM
Mike Brackins's Avatar
Mike Brackins
Cool starting problems '04 6.0
I have a 2004 ford f-250 powerstroke 6.0. Three weeks ago it started getting hard to start. I started plugging it up at night. It would start easily in the mornings after doing so. Wednesday I drove it to work and when I got ready to leave in the afternoon it would not start. I plugged it up for a few hours a still nothing. I unplugged the ICP sensor and still want start. The FICM reads 47.6 with key on. When the motor turns over the reading is 11.5. Since the motor never starts is this an good reading? Where do I need to start at.
Old Jan 21, 2013 | 01:25 PM
mustang_309's Avatar
mustang_309
No that FICM voltage should stay around 48 at all times, from key on, cranking, idling and wide open throttle. Sounds like its time to pull your FICM and send it to Ed at FICMrepair.com . Also take your batteries and have them load tested separately ( completely disconnected from one another) and if you find one bad battery replace them both.
Old Jan 21, 2013 | 01:29 PM
mustang_309
Actually anything above 45 volts is supposed to be ok, but at 45 volts the FICM is on its way out.
Old Jan 21, 2013 | 06:37 PM
bismic's Avatar
bismic
Personally, I wouldn't want to have 45V on the FICM. I would be having it fixed.
Old Jan 21, 2013 | 07:01 PM
mustang_309
Agreed and X2 what you said
Old Jan 21, 2013 | 07:28 PM
Mike Brackins
Thanks for the great replies. Sending it off tomorrow.
ShawnQ
Feb 26, 2019 09:36 AM
Dogman_528
Nov 20, 2015 09:15 AM
crawler87
Apr 22, 2014 10:53 PM
bigtdriver
Apr 17, 2014 10:41 PM
reno13
Sep 30, 2012 08:57 PM
