Sponsored by: Kumho
steering pulls
Old May 28, 2003 | 11:31 AM
myred79's Avatar
myred79
Unhappy steering pulls
I have a 1979 F-150 lifted with 35" tires and i took it mudding and got back into it to drive it and now it pulls pretty hard when you drive down the road. When you drive down the road it all of the sudden just jerks (usual to the drivers side). The only thing i noticed is that on the dual front stablized the bottom one is dented in. I was wondering if this was my problem or if i needed to get it aligned?
Old May 28, 2003 | 12:19 PM
mrwizard's Avatar
mrwizard
steering pulls
You had to have hit something to dent the stabilizer. This could also have bent or otherwise damaged something else in the steering/suspension system. The easiest way to tell would be to pull out that damaged stabilizer and see if it helps or not. However, I would certainly plan on taking it to an alignment shop pretty soon.
Old May 28, 2003 | 02:37 PM
RBrendel's Avatar
RBrendel
steering pulls
every time your springs compress they throw the camber out. ive found that if i hit a bump to hard i start to pull to the right. now ive just given up. lifted ifs is a pain in the ***. just go to the alignment shop
smittys5xs
1978 - 1996 Big Bronco
Nov 26, 2012 02:42 PM
jeregrl
Offroad & 4x4
May 15, 2008 07:38 PM
Obtuse1
1983 - 2012 Ranger & B-Series
Jun 15, 2007 05:00 PM
radtech
Feb 2, 2005 09:13 PM
sud z
Oct 15, 2002 01:16 PM
