Turn signals blinking way too fast, then stopped working
As the title says, my turn signals have been acting really weird recently. They'll blink 2-3x normal, and sometimes they'll just slow down and slow down, and then speed right back up to that really fast speed.
But then just today, they stopped working completely. No flasher icon, no lights, nothing. My emergency flashers still work fine, and none of my bulbs are burnt out
I haven't done any recent modifications. Don't have LED bulbs, just the normal stock lights. Only change has been that it's been really cold this winter (0-15 F or so)
Any ideas?
Any ideas?
X2^^^^^^
And there WILL be a fuse, every circuit in the truck is protected by a fuse, breaker, or a fuse link.. The turn signal circuit IS a fuse, it will probably protect other circuits as well...
The flasher is on the fuse panel under the dash.
Well, if the cab is set up anything like my '96 F-150 there should be a panel, about knee level on the drivers side. Remove that panel (it has a hand hold on it) and towards the upper right you should see a silver cylinder ohhh about two inches in diameter and about half an inch tall. That's the turn signal fuse.
