dp f-5 switch
Old Jan 19, 2013 | 01:01 PM
medhvac's Avatar
medhvac
dp f-5 switch
i have no power to my dp tunner f-5 switch truck not starting well crank over any easy way to fix this or get truck started?
Old Jan 19, 2013 | 01:15 PM
tjc transport's Avatar
tjc transport
i ain't rite
make sure the cable is fully plugged into the chip and the switch.
every once in a while it will unplug from the back of my switch causing a no start.
Old Jan 19, 2013 | 01:27 PM
medhvac's Avatar
medhvac
its connected i get a little green light for a second thats it
Old Jan 19, 2013 | 01:31 PM
tjc transport
i ain't rite
not sure on that .
best bet would be to contact DP. 828-221-0076
Old Jan 19, 2013 | 01:32 PM
tappit01's Avatar
tappit01
i would try cleaning up all the contacts if you hav'nt done so already.
Old Jan 19, 2013 | 01:35 PM
medhvac's Avatar
medhvac
thanks i left message with dp they must be closed
Old Jan 19, 2013 | 01:48 PM
medhvac's Avatar
medhvac
i did that 5 years ago when i installed it!lol
Old Jan 19, 2013 | 01:54 PM
BigAlsPSD's Avatar
BigAlsPSD
You are in "No Start" if you are getting the small dot. Do you know how to get out of it?
Old Jan 19, 2013 | 02:01 PM
Stewart_H's Avatar
Stewart_H
Knowledge Base - Troubleshooting, No start issues - Chip Troubleshooting, No Start Issues
Stewart
Old Jan 19, 2013 | 02:15 PM
medhvac's Avatar
medhvac
no i do not
Stewart_H's Avatar
Stewart_H
Originally Posted by medhvac
no i do not
See my post above yours.
Stewart
Old Jan 19, 2013 | 02:17 PM
Km1210's Avatar
Km1210
To add to Stewarts post, they also have videos that might help as well.
F5 - DP-Tuner TV
Old Jan 19, 2013 | 02:18 PM
BigAlsPSD's Avatar
BigAlsPSD
no i do not
As Stewart posted...press the (-) for 3 seconds. I was going to post it earlier but figured I would try to keep the "bad guys" from it as much as possible, but it really doesn't matter I guess.
Old Jan 19, 2013 | 02:19 PM
medhvac's Avatar
medhvac
sweet your the best! that worked thank you very much
Old Jan 19, 2013 | 02:20 PM
Stewart_H's Avatar
Stewart_H
Well, when the info is posted for all to see on the 'net at DP's own site, plus all the many threads and posts over many years covering this exact subject with specific instructions on all the many different diesel forums all over the 'net, I'm pretty sure one less post here at FTE (which already has a plethora of posts covering this topic) won't matter in the grand scheme of things.
Stewart
