Considering an upgrade, Advice needed
Its probably time for new plugs, which is going to be a pain...but other than that I don't know why. I don't drive it hard either. Its not like I mash the pedal when I take off.
I intend to change the plugs early spring. I'm not looking forward to it though. I do have the plug removal tool though in case I need it. I'm keeping my fingers crossed.
Good thing you have the removal tool, it will most likely be needed. The plugs really aren't as bad as most people make it out to be, it can just be time consuming removing the broken plugs. Once you figure out the removal tool, you'll agree.
I still believe re-gearing will help your fuel mileage... but in your situation I think I would upgrade to the newer truck if the money isn't a problem. My brother thinks that the 5.4 puts out more power than than the 5.0. I personally think he is a little biased simply because that is what he owns.
My '12 is a wonderful truck and much nicer in every way than my '04 was. More room, power, fuel mileage, and features.
I can understand the concern about the early production of the EB/5.0 and supposedly the 2014s will have the next generation EcoBoost motors... not sure but I imagine the 5.0 will be updated as well. Something to think about.
It all boils down to what feels better to you. If it were me and I could afford it... I would upgrade ASAP.
1.I ran Lucas fuel injection cleaner, mixed at 3 times their recommendation in 1 full tank of gasoline. Purpose…if I was lucky, it would dissolve or loosen any carbon buildup (although many do a real fuel injection cleaning also- and it is probably a best practice to do if you have more than 45-50,000 miles on the plugs)
2. Although I am a fan of PB Blaster, I used a product called ChemSearch “Yield”. The issue I have with using carb cleaner is the lack of lubrication…..in the old days of removing steel plugs from aluminum heads, we use to mix up acetone & ATF…or of we needed more lubrication, kerosene & ATF, “Yield” provides this lubrication- much better IMHO than even PB Blaster.
3. Yes, I put anti-seize on the plug threads (I know the TSB says not to)
4. Of course…a lot of patience, I really doubt if I ever put more than 20-25 lbs of force during removal (purposefully)
The end result, only one plug even “squeaked” coming out (but it basically unscrewed like a regular plug- literally). Plug #4 was initially a little stubborn, but after the second try, then waiting about 30 minutes, it came out with very little effort…just kept wiggling the plugs (tightening/loosening) by 1/8th or even less of a turn- and they all came out without a single one breaking or any issue really. Another technique that can definitely be used is to loosen the plugs about 1/8 of a turn, start the engine for about 30 seconds to 1 minute- this allows the flame to travel up around the plug to burn off the carbon, let cool, then remove with the process I previously described.
As far as using an air ratchet, I can understand the theory of “shocking” the carbon loose, but I have also seen and experienced in my younger days some real disasters.
Actual working time: 2 hours…..including washing my hands, total time was 5 hours.
FYI- Why I choose Motorcraft.
In the 1970’s I ran (like many) Champion’s in just about everything (even had the gold palladiums), but stopped in the early 1980’s when they changed their copper-core design and the resulting quality problems that IMHO still exist today. Since then I have run Splitfire (non-platinum) in my old world (1960’s) cars, Bosch in my late 1990’s vehicles (both because the cylinder head design really prefers these types of plugs), but I really had hesitation because of the construction/component quality of the non-Motorcraft plugs and really questioned the durability in this application about the Motorcraft SP508 or SP 509’s which are single platinum. Given the types of loads and burn/flame promulgation rates in the chambers, I really had doubts about the style of the plug with single platinum having the ability to “survive” as long as they engineers said. What do ya know…the SP 515’s are double platinum.
