Sponsored by: Real Truck
auto to manual
Old Jan 17, 2013 | 08:50 PM
mj_355's Avatar
mj_355
auto to manual
I have a 1999 f-250 sd with 5.4 auto trans and switch operated transfercase. Im going to install my 1998 12valve cummins, nv4500 manual trans, and the manual dodge transfer case. I need some info on making it from a auto to a manual trans. Iv bought several items already like manual lock outs, clutch pedal setup, manual column plastic, master cylinder slave cylinder setup, and probly some things iv forgot about. I want to make it look like it came from factory as a manual. Now on the column how do I go about making it fuction and look stock? Any advise would be great on the changeover
Old Jan 18, 2013 | 06:29 AM
redford's Avatar
redford
FTE Leadership Emeritus
You need to find a column from a manual shift truck, or take off the automatic shifter and find some sort of sleeve that will cover it up.
Old Jan 18, 2013 | 08:30 AM
mj_355's Avatar
mj_355
I have the column plastic from a manual already bought
Old Jan 21, 2013 | 03:00 PM
mj_355's Avatar
mj_355
is there anything else I need to be looking for?????
Old Jan 21, 2013 | 07:47 PM
nagataOSU's Avatar
nagataOSU
Here's a thread I've had bookmarked for a while, it's a write-up from a guy who did an auto-to-ZF6 manual swap: 99 F250 auto to manual swap COMPLETE! - Ford Powerstroke Diesel Forum
Not exactly the same swap you're looking to do, but it's a great write-up with lots of details, hopefully it helps you out. I'm hoping to swap a ZF6 into my '99 CC V10 auto...
csangster
Jan 23, 2019 02:18 PM
F-250 restorer
Aug 12, 2014 05:54 PM
JerrywallaceII
Feb 26, 2012 12:48 PM
jsmith8686
Feb 13, 2011 09:16 AM
SnuffthePunkz
Aug 21, 2010 04:45 AM
