ABS Module Issues
Old Jan 16, 2013 | 07:01 PM
george14094's Avatar
george14094
ABS Module Issues
Please Help, I have a problem with my 2004 f350 with a 6.0. The speedometer stopped working, abs light is on, Cruise stopped working and have just figured out that the truck will engage 4x4 but will not dissengage. I have replaced the speed sensor traced the wiring and connectors throughout the whole system at this point. I am getting no codes and cannot communicate with the speedometer or transfer case through the scanner. I have voltage coming into the abs module but nothing coming out of the five outputs. Any thoughts or ideas would be appreciated.
Old Jan 17, 2013 | 10:31 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I can't help you, but I'll respond as to bump your issue back to the top.
Old Jan 17, 2013 | 11:08 AM
cartmanea's Avatar
cartmanea
Check all the ABS fuses. I think there is a small one and also a larger 60A fuse.
Old Jan 17, 2013 | 02:14 PM
george14094
Have checked all the fuses many times hoping that was the issue, all are good. Any other thoughts?
Old Jan 17, 2013 | 02:16 PM
cartmanea's Avatar
cartmanea
Could be the ABS module failing. I had one damaged in an accident and found one in a salvage yard pretty cheap.
Old Jan 17, 2013 | 06:31 PM
cheezit's Avatar
cheezit
ok so you have 12v going in. do you have grounds?
did you use a freq meter at both ends of the speed sensors?
you cant access the x-case with any scan tool, just the tcm and its part of the pcm/ecm
Old Jan 17, 2013 | 07:25 PM
cartmanea's Avatar
cartmanea
AE shows xcase codes, and ABS codes. You might try to find someone with an AutoEnginuity to scan it.
teastek
Jun 14, 2017 08:54 AM
smittys5xs
1978 - 1996 Big Bronco
Mar 12, 2015 10:11 PM
fancyketchup
Feb 20, 2015 10:15 AM
george14094
Jan 17, 2013 11:13 PM
dodgefreak8
Sep 20, 2008 11:21 PM
