Sponsored by: Real Truck
what could it be???
Old Jan 16, 2013 | 01:09 PM
06 CC 250's Avatar
06 CC 250
what could it be???
i have been having a problem with my 06 f250 5.4 running lean (p0174). took it to the dealer yesterday and they did a smoke test, checked fuel injectors, fuel pressure, and hooked a laptop to it and did a road test. everything checked out good. at wot it hesitates, kinda jerks, and bucks, but normal highway driving it does fine. the idling is pretty good, but fluctuates a little when shifting from forward to reverse. they said at wot cylinder number 5 was dropping out (whatever that means). the mechanic told me he would start by changing the plugs. the truck has 75000 miles on it, with the original plugs. does anyone think it could be the plugs? or could it be something else. i dont think the tested the coils, they didnt say anything about them. i would appreciate any help i can get thanks.
Old Jan 16, 2013 | 02:32 PM
dlibson's Avatar
dlibson
Sounds like a possible maf issue, or you could have the start of cats failing too. Are you lacking power?
I would do plugs if it is dropping out, but it isn't the cause of your code.
Old Jan 16, 2013 | 05:35 PM
redford's Avatar
redford
FTE Leadership Emeritus
If it was the plugs there would have been a misfire pending code.
Old Jan 17, 2013 | 04:16 AM
06 CC 250's Avatar
06 CC 250
if it were the maf wouldnt i be getting a lean code for both banks instead of just one?
Old Jan 17, 2013 | 04:18 AM
06 CC 250's Avatar
06 CC 250
a few weeks ago i got a p0300 code (random misfire) but i havent seen that code since i cleared it
Old Jan 17, 2013 | 05:50 AM
dlibson's Avatar
dlibson
Not always. I am leaning more towards a cat problem anyways...
Old Jan 17, 2013 | 06:04 AM
redford's Avatar
redford
A catalytic converter problem is very possible. If you have a partial clogged cat, you won't be able to flow enough exhaust at high engine speed, but at normal engine speed your engine runs fine.
Old Jan 17, 2013 | 09:26 AM
Furian's Avatar
Furian
You Keep What You Kill
I believe that catalytic converters are covered under a 8 year / 80K emissions warranty... Considering that your F250 has 75K miles, you need to get the dealership to fix them asap.
See Page 12 in the link below.
http://www.motorcraftservice.com/pub.../06frdwa5e.pdf
Old Jan 17, 2013 | 11:41 AM
06 CC 250's Avatar
06 CC 250
it could possibly be the cats failing, because i used to hear a real bad rattling noise from the exhaust if i was coasting around a curve and then when i would get back on the gas a little it would rattle bad. i always just assumed it was just a loose heat shield or something. maybe the rattle was loose media moving around or something.
i guess i need to have the shop check them, but they will probably try their best to get around replacing them under the 8 year/ 80000 mile warranty.
Old Jan 17, 2013 | 11:49 AM
Furian's Avatar
Furian
The OEM catalytic converters are outrageously expensive!
trucks12345
2004 - 2008 F150
Feb 19, 2015 09:09 AM
Craig Minds
Nov 25, 2013 09:48 PM
jimjoebob99
Nov 14, 2011 07:30 AM
surferbum
May 28, 2007 01:54 PM
MEMO847
Jan 4, 2006 09:39 PM
