06 FX4 5.4L Starting Issues
Old Jan 15, 2013 | 08:16 PM
CanAm09's Avatar
CanAm09
Hey Everyone,
Recently my F150 has had issues starting in the mornings. It is in an insulated garage. It takes about 10 cranks before it fires. Then it struggles to run like its not getting fuel for a second or two, then rpm's jump to 1200 and has a slight miss for another second or two, then it smooths out and is fine. Leaving my driveway it will have a miss around 2000rpm for about two seconds then the truck will run perfect the rest of the day. It can sit outside in the cold for 10 hours while i am at work and will fire right up and run great. The issues only happens in the morning. All the plugs were changed abot 6 months ago. Fuel pump and fuel pump drive module were changed about 3 weeks ago. The check engine light has come on twice. the first time i didnt have access to a code reader and since the truck started right away and then died instantly i figured that was why the light came on, so i disconnected the battery and re-connected it. Light didn't come back on for a week. Second time code was for misfire on cylinder 5. I am changing the fuel filter this week. If that doesn't work i was gonna change the #5 coil. Any other suggestions?
Thanks
Old Jan 16, 2013 | 06:04 PM
CanAm09's Avatar
CanAm09
Not fuel filter
Whitetale
2004 - 2008 F150
Jul 25, 2018 02:46 PM
mhofmann86
Sep 22, 2015 03:45 AM
ChrisCarter
2004 - 2008 F150
28
Jan 25, 2011 06:02 AM
TopThis8899
Mar 8, 2007 09:30 AM
