Need some engine info..
Old Jan 14, 2013 | 07:10 PM
karenmascaro's Avatar
karenmascaro
1976 f100 custom with a 351 Cleveland, possible to have been factory?
Thanks
Old Jan 14, 2013 | 08:18 PM
HIO Silver's Avatar
HIO Silver
According to the most reliable sources, no... the Cleveland was discontinued in the US after 1974.
Old Jan 14, 2013 | 08:31 PM
1975MudRat's Avatar
1975MudRat
No. I'm not sure if the Cleveland was available in "Dent Sides". Not 100% but I thought the Cleveland was a car engine.
Old Jan 14, 2013 | 08:38 PM
HIO Silver's Avatar
HIO Silver
It was not available in the Dents. IIRC, it was available in the 67 Bump. Hence.
Old Jan 14, 2013 | 08:44 PM
1975MudRat's Avatar
1975MudRat
Ok, thank you for the clarification!
mikeo0o0o0's Avatar
mikeo0o0o0
Didn't the Clevelands come out in 1970?
No Clevelands in dents'.
In '76 2WD you could get the 300 6 cyl, 302, 360, 390, or the 460 V8s.
4WD 300 6cyl or 360 V8.
xkpsanit's Avatar
xkpsanit
70 to 74 car only
Old Jan 14, 2013 | 08:51 PM
7636074460's Avatar
7636074460
wow no wonder dont see very many then! 70-74 cars....
and 4WD only came in 300/360? wow.
Thats what i love about this forum i thought i knew a lot but learn everyday!
Old Jan 14, 2013 | 09:26 PM
xkpsanit's Avatar
xkpsanit
...and some 74 LTD modified's had a small block bellhousing . what else do you need to know ???
Old Jan 14, 2013 | 09:31 PM
HIO Silver's Avatar
HIO Silver
You're right... I'm thinkn of the 352FE being available in 67 Bumps as a one-year only availability... not the Cleveland.
Old Jan 14, 2013 | 09:36 PM
1975MudRat's Avatar
1975MudRat
Yes. The 352 was replaced in 68 by the 360 FE. The 352 only had a run from 65-67.
Old Jan 15, 2013 | 04:51 AM
karenmascaro
How can I determine what engine is in mine?
Old Jan 15, 2013 | 05:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by karenmascaro
1976 F100 Custom with a 351 Cleveland, possible to have been factory?
Absolutely not. 351C installed in misc 1970/74 Ford/Merc Passenger Cars & Ford Ranchero's only.
1976 F100 2WD: 300 I-6 standard equipment. 302, 360, 390, 460 optional / 1976 F100 4WD: 300 I-6 standard equipment, 360 optional.
The engine code is the 4th digit of the VIN ~ 1976 F100: B = 300 I-6 / G = 302 2V / H = 390 2V / J = 460 4V / M = 390 4V / Y = 360 2V.
Old Jan 15, 2013 | 05:52 PM
1975MudRat's Avatar
1975MudRat
Was the 460 ever available in 4wd?
Old Jan 15, 2013 | 06:00 PM
NumberDummy
460 4WD: 1983/97 F250/350 only, ditto 460 w/a M/T.
