with the lariat interior package is there a rear view camera display in the rear view mirror, and one in the dash aswell? if so can the one in the dash be turned off to where you just have the display in the rear view mirror only?
Thanks, Tim
My 2013 F250 Lariat shows the backup camera in the 8" sync display.
Mine is off to the side slightly so now I just backup with the line lined up to the side of the ball and it works perfect.
Originally Posted by edjunior
Exactly. Just what he said.
X3
I don't believe having a monitor in the mirror and the Nav screen is possible from the factory (it's one or the other). The screen on the Lariat (driver information center) in the center gauge cluster is not able to be hooked up to a back up camera...just for information.
I believe if you loosen the handle via the bolts inside the tailgate you can move it slightly. Mine was right on and after I installed the tailgate automatic lock it is a little off. Just have not had time to try and adjust it back. Maybe if it warms up a bit I will try soon!!!
Hey thats a great idea! I will give it a try as well. If it works I will report in.
