idol problem
Old Jan 13, 2013 | 09:52 PM
rameyme's Avatar
rameyme
idol problem
i have a 1990 f150 5.8 when it idols down after start it will idol down and amost die then up it will do this a few min then die anybody have any idea why
Old Jan 13, 2013 | 10:52 PM
timbersteel's Avatar
timbersteel
May try to clean the IAC valve located on the throttle body. Unplug the sensor connector. Remove the 2 screws attaching it, careful not to damage the gasket if possible. Clean well with brake cleaner or electronic cleaner and be sure to keep the solenoid part dry and free from any chemical.
Old Jan 14, 2013 | 07:52 AM
Freightrain's Avatar
Freightrain
Welcome to the forums.
Yup, I'd check into the IAC first. If they get cruddy, they will get sticky and not work smoothly. Thus your idle will surge.
Old Jan 14, 2013 | 10:12 AM
garrett_8's Avatar
garrett_8
Billy IDOL is not a problem
idle on the other hand
Old Jan 14, 2013 | 11:36 AM
rameyme's Avatar
rameyme
thanks guys i think that fixed the problem
Belial
May 7, 2017 12:26 AM
Keepitrunnin
Jun 2, 2006 11:42 AM
93candycane
Nov 16, 2004 09:32 AM
duke1234
Dec 28, 2003 07:14 PM
BeauGT
Dec 24, 2003 12:21 PM
