Reverse light woes
Old Jan 13, 2013 | 04:16 PM
Boba Fett's Avatar
Boba Fett
Reverse light woes
Does anybody know of an off the parts store reverse light switch I can use to replace a Hurst shifter mounted reverse light switch?
I have a short in the wiring and after troubleshooting the situation I am pretty sure my short is due to water/moisture causing the Hurst switch to short to ground on the brackets or shifter
Old Jan 13, 2013 | 04:20 PM
xkpsanit's Avatar
xkpsanit
Gotta be a standard micro switch, check Grainger
Old Jan 13, 2013 | 05:21 PM
jim collins's Avatar
jim collins
Take it to NAPA and let them match it up . I picked up a couple last summer but I tossed the part #. I used one for a safety start switch on a street rod.
toofazt
13
Nov 4, 2016 03:58 PM
andrewbragg
May 16, 2013 09:31 PM
aintskeered
Feb 3, 2012 09:59 AM
oldmerc
Nov 27, 2011 08:46 AM
ATC_250SX
Mar 4, 2005 10:15 PM
