Sponsored by: Real Truck
repacking bearings
Old May 27, 2003 | 06:44 PM
melissa abbott's Avatar
melissa abbott
Question repacking bearings
I have a '99 f-250 sd sp ex-cab 4x4, and i know that it is past time to repack the bearings but, they are different than my last truck. could someone please help?
Old May 27, 2003 | 10:13 PM
RRMike's Avatar
RRMike
repacking bearings
You cannot repack them. They are a sealed bearing. Non-serviceable. They are supposed to last longer but when they go they have to be replaced.
Old May 28, 2003 | 07:44 PM
V10man's Avatar
V10man
repacking bearings
Expect to pay +/- $300 each.
Old May 29, 2003 | 10:46 AM
garymake's Avatar
garymake
repacking bearings
How much longer are they suppose to last ?
In over 30 years of owning cars and trucks (many of which went well over 100,000), I've never had a bearing fail. Of course, I've also made sure they were repacked every 30,000 miles, but still...
Why, when something isn't a problem, do they feel the need to fix it (usually with a fix that ends up costing me more $$$)?
Old May 29, 2003 | 09:03 PM
FortyFords's Avatar
FortyFords
repacking bearings
Gary ! ,Because we live in a throw away society!
(spelling)
Why no grease fittings from factory ?
so we must by new and throw away the old !
we fill our land fills with this stuff !
If we rebuilt things like we did in the old days
New cars would sit on lots!
Don't get me started on this guys or gals !
Melissa ,if you want bearings that are repackable
you can spend about $1500 for a dyna-trac front hub setup! when yours go bad!
Rich
Old May 30, 2003 | 12:16 AM
Motoxman_117's Avatar
Motoxman_117
repacking bearings
300.00 each? that is rediculous! mine are due to be replaced also. Does anyone make some repackable replacements for cheaper than 300.00 each?
Lee
Old May 30, 2003 | 08:53 AM
RRMike's Avatar
RRMike
repacking bearings
Don't quote me on this but I heard more like $360-$385 for one side for parts only.
My understanding is that you have to buy a conversion kit with new hubs and spindles to fix the problem. Dynatrac makes the only kit that I'm aware of. There may be others that I'm unaware of though
Old May 30, 2003 | 09:55 AM
ldcattle's Avatar
ldcattle
repacking bearings
What year did Ford start using the non-serviceable bearings?
This is the first I've heard about it. I have a 96 F350 CC SRW and was just thinking the other day about repacking.
Old May 30, 2003 | 10:33 AM
CBSuperduty's Avatar
CBSuperduty
repacking bearings
I thought that I read some where (probably at TDS.com) that NAPA and some other places were going to be getting some repackable bearing that were a lot cheeper. I will see if I can dig up that info...
Old May 30, 2003 | 01:30 PM
RRMike's Avatar
RRMike
repacking bearings
Ford went to the sealed bearing in the superduties. Your 96 has the greasable type I think.
Old May 31, 2003 | 09:02 AM
stumpy2's Avatar
stumpy2
repacking bearings
Yes..Sealed bearings Suk!! Anyway, there was a thread on here about a fella desighning a set or fixed bearing hubs for our beloved Super Duties. The Dyna Trac Kit is high I think. I think his name was lw555 that was building the hub kit. Hey...where you at LW??????? any updates for us? I think when a kit becomes available and my bearings go, I will convert then.
Stumpy2
2K1 SD EC SB 4x4 5.4 AT 4:10 LS 3 1/2" Lift 315/75-16's TRUE BLUE
Old May 31, 2003 | 09:06 AM
Bob Ayers's Avatar
Bob Ayers
repacking bearings
I'm not sure what year they started, but the newer Rangers have
sealed bearings also...
Old May 31, 2003 | 03:31 PM
LW555's Avatar
LW555
repacking bearings
I've heard rumors that more than one company will be making a hub kit for our trucks (besides me). I can't say anything now about mine, since I don't pay for advertising and that wouldn't be fair.
Meanwhile, the cheapest place I've seen the unit hubs is at fordpartstore.com for about $270. Problem is, they are listed under rear wheel bearings and don't show up if you look for front wheel bearings. Look up "Bearings and Seals" for the group, then "Bearing,Wheel,Rear Hub Assembly" for the part. You'll see part numbers 515020 and 515021 which are the most common.
Old May 31, 2003 | 07:00 PM
Streetcruzer's Avatar
Streetcruzer
repacking bearings
(spelling)
Rich
You hit it on the head Rich, throw it away or bulldoz it down, make room for progress they say!!
Well I just learned something, I can't repack my wheel bearings and its going to cost a week's paycheck to replace them. Is'nt that just great!! I wonder what other surprise's I'm in for.
Lenny
Old Jun 1, 2003 | 05:30 PM
Motoxman_117
repacking bearings
I wonder if you can just call timken bearing company or with the spec and ask them if they have an equivalent bearing?
MotoX
