Alright, so I marked and then dropped the rear driveshaft. While the wheels were up in the air without the drive shaft, I spun them by hand and could hear some noise. Couldn't tell exactly where it was coming from - the rotor area or from the diff itself.
Anyway, I put it in 4 wheel drive and took it for a spin. The rolling noise is still there. I guess that this weekend I will pull the calipers off the rear and spin it by hand and see if I can hear any change in the sound. Then I guess I will pull the axles and see what the wheel bearings look like. Then look at the diff? Could the noise be in the t-case or trans? It is there while I am rolling even if I throw the trans into neutral.
I am at a loss here. I really hope this isn't a differential issue. I am beginning to think it was a mistake to buy this truck.
so if you pull the calipers and the noise is still there then it is time to pull the axels and determine if it is wheel bearings or carrier bearings.......or parking brake?
I just had a thought, what of a lining seperated from a shoe on a parking brake? I would investigate the side that has the tight parking break lever first, that sounds fishy.
I dont think you have a diff failure , everytime I have had a diff failure it has gone "click click" then "clunk" accompinied by the smell of burning gear oil.
Don't smell burning gear oil do you?
No, I don't smell burning gear oil. The lining seperation is a new idea.....
That's a great suggestion, could certainly be a delaminated shoe. I was thinking a broken spring, but either way you'll find out once you get the rotors off.
Yeah, but chances are you will never have to replace rotors again. I did all four rotors and added ceramic pads back in 09. I look at them when I rotate tires. Other than road dust they look new.
Devin, I was gonna respond but these guys took all my suggestions. You will love that truck once you get the bugs fixed.
I have this same "rolling noise" on the right front wheel area of my truck. It's deffinitely a dull rattle rolling tumble (lol) noise. And more prominant when the passenger side window is down. I also hear the noise rattle when I go over the lane markers at slow speed or a speed bump. I bought the truck 3 months ago and drove it for a month but didn't hear the noise until I had the tires rotated. I also had both front lower ball joints replaced the same day. Now I'm in no way saying it's in the tire but something deffinitely jarred loose when they re-mounted the tires. I've done an inspection on the entire front drive train and brakes with no luck of finding anything loose. Keep this thread pumping full of ideas please.
Your problem will probably be a bit different as it's on the front axle, so please post a new thread so we don't hijack Devin's.
Briefly though and assuming you have a 4x4, elevate the suspect wheel and give it a spin with and without the hub manually locked and see if that makes a difference. That'll help isolate the cause.
Sorry about that- I have an 02' F250 4x4 7.3 12" lift on 38's. I set the front end on jacks last weekend and rotated both front wheels. I did it with the hubs locked and unlocked. I didn't hear the sound at all, I only heard the noise when the truck was rolling.
Try pulling your ABS sensor and put 5-10 squirts of grease in there. See if lubricating the wheel bearing quiets the noise while the bearing is loaded. Hopefully just a dry bearing and not damaged mechanically.
Greasing the splines on the ds and checking universals. I went threw 2 universals in less than 10k miles. Turned out the drive shaft was out of balance and was chewing threw them.... Literally I still have one of them in my center council as a conversation piece
I dropped my rear driveshaft last night and drove it in front wheel drive last night to see if it was the carrier bearing or rear driveshaft u-joints. The sound was still there even with the rear driveshaft removed.
