2003 Explorer 4X4 will not engage
Old Jan 13, 2013 | 12:46 PM
Chris Ayers's Avatar
Chris Ayers
Cool 2003 Explorer 4X4 will not engage
I have a 2003 Explorer, I went to use the 4X4 the other day and the light comes on when I switch it 4H or 4L but nothing else happens. So I am thinking it might be the 4X4 mod. How can I test it or do any of you have any other ideas?
Please help me if you can..
Thanks
Old Jan 14, 2013 | 11:40 AM
rrgone's Avatar
rrgone
Thanks
Welcome to FTE.
This could well be a loose/damaged connector on the transfer case. If the ground is not good it will not work. Check the connector carefully. It is located on the back of TC shift motor.
Let us know what you find. Good luck.
Old Jan 14, 2013 | 12:26 PM
impish's Avatar
impish
Check for trouble code(s).
The PCM knows if current flow to the shift motor occurs, thus enabling it to detect a failure in wiring. However, it does not know if the motor moves or not. In 4H the motor is not activated, only in 4L.
Are you certain there is no drive to the front wheels in either mode? impish
Old Jan 14, 2013 | 01:37 PM
aquanaut20's Avatar
aquanaut20
If you have the AUTO hubs, they have failed and need maintenance (common)... Philip
xxcoldbeerxx
Feb 1, 2009 05:20 PM
lovemy150's
Jul 5, 2007 01:41 PM
911bear
Mar 8, 2005 04:53 PM
whitingjk
Feb 23, 2004 08:10 PM
earlsfork
17
Feb 11, 2004 04:05 AM
