buying a 390 fe
Old Jan 12, 2013 | 08:51 PM
gmill09's Avatar
gmill09
buying a 390 fe
thinking about buying a 390 from ford parts. 1975 Ford F-100 Engine Long Block | FordParts.com
Seems legit since its from ford themselves. Anyone got any better ideas?
Old Jan 12, 2013 | 09:07 PM
vwfreak's Avatar
vwfreak
You better live close as it's not shippable....
Old Jan 12, 2013 | 09:12 PM
gmill09's Avatar
gmill09
i live about 60 miles from the store it says im shopping out of. I'm curious to how well the engine will perform though
Old Jan 12, 2013 | 09:31 PM
vwfreak's Avatar
vwfreak
oughta perform like a stock 390....!
Old Jan 12, 2013 | 10:53 PM
gmill09's Avatar
gmill09
what can i do to give a stock engine a bit xtra hp. i have no idea what a stock 390 has but i would like 375-400 hp
Old Jan 13, 2013 | 10:41 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Well, a stock 75 truck 390 was down around the 200 HP mark, which is about all you'll be able to get out of the one you linked to. ~8:1CR just kills the power potential in a stock truck 390.
Earlier 390's used in cars were rated 300+ HP/400+ TQ. You *could* get there pretty easy with that "stock" engine, you would just need to change the cam/lifters, timing chain/gears, and pistons. That's a lot of stuff to change in an engine that already has a high price tag on it.......
Old Jan 13, 2013 | 11:04 AM
gmill09's Avatar
gmill09
yeh i thought i read something like that a few years ago, but wasn't sure. partially why i started this thread. but nonetheless thanks a lot
Old Jan 14, 2013 | 09:50 AM
MIKES 68 F100's Avatar
MIKES 68 F100
for about the same $ you can get a mild built long block from survival, tuff dawg and a couple others .
Old Jan 14, 2013 | 10:10 AM
gmill09's Avatar
gmill09
yeh, im trying to decide whether to have mine rebuilt for 6k or buy one from TNT Engineering for 5k plus 450 shipping . The machine shop will remove n install for free and they have a 3 year / 75k mile warranty. As of now im leaning towards rebuild
Old Jan 14, 2013 | 10:42 AM
MIKES 68 F100
check out Tuff dawg , pretty sure their prices include shipping .
Old Jan 14, 2013 | 10:49 AM
vwfreak's Avatar
vwfreak
They are supposed to build a good motor too.
They are here in PHX somewhere.... They were an option I considered but I wanted to do my motor myself.
Old Jan 14, 2013 | 02:19 PM
gmill09's Avatar
gmill09
thanks guys. I found 1 i'm going to get from there . Ford 390/422hp - Tuff Dawg Engines
What all will i need to add to the crate engine? I have a 428 and is there anything from that engine i shouldn't worry about using on it? i know i will need a flywheel
Old Jan 14, 2013 | 02:36 PM
MIKES 68 F100
that's a great motor for the $$
you tube video of their 400hp on dyno
Old Jan 14, 2013 | 09:31 PM
gmill09's Avatar
gmill09
is removing and installing an engine hard work? i have a tractor and am thinking about installing it myself to save money
Old Jan 14, 2013 | 11:09 PM
85e150's Avatar
85e150
Tractor with a loader, right? Remove the hood and radiator (imo).
Not sure you can put the engine/trans/exhaust headers (?) in all in one piece due to frame clearance issues. If you can, that makes some things easier.
For a big V8, you really need two people. One to operate the loader and one to eyeball, twist and turn the engine.
It's not "hard work", but you must pay attention to details like grounding straps, heater hoses, make sure you don't knock the brake booster off the firewall, stuff like that there. Lots of little things.
If you can't load the engine and trans together, then hooking the engine and trans up takes some doing. Again, two people make it a lot easier.
Others will chime in with helpful hints.
Of course, the main question might could be--how much money are you going to save?
