54 f100 hood issues
54 f100 hood issues
hello everyone,im Tony, I am working on a 54 f100. I am hanging some sheet metal and am having issues with the hood closing. when I attempt to close the hood it is about 3" away from closing and wont go anymore. What am I doing wrong? I am trying to upload pictures amd am having some difficulties doing that too.
Do a forum search on "53-56 front sheet metal alignment procedure" or go to:
https://www.ford-trucks.com/forums/s....php?t=1019537
If using a phone (mobile site link, might redirect OK).
Are you using the special shoulder bolts and spring (wavy) washers to attach the hinges to the hood? The arms should not be bolted tight, the bolts should be just barely snug and safety wired so they don't back out. The 54 hinges should have 7/16" holes in the ends of the arms. I have written a number of posts on how to verify that the hinges are working properly, there is a pivot that is hidden under the springs that is often frozen or stiff. Do an advance search on my user name and hood hinges to find one. Often people think the spring should be wound tight as well.
I have also written a detailed procedure on how to align the front sheet metal several times, here's one: https://www.ford-trucks.com/forums/1...ml#post9927171
Note that WD40 is not a penetrating oil or a good lubricating oil, it only worked by good luck. The hinges will soon bind up again. lubricate with a lubricating or motor oil or grease (Tip: in a pinch you can pull out the engine dipstick and apply a drop of engine oil off the end of it.) Oil is messy tho, it would be best to disassemble the hinge and apply some good grease to the pivot points, especially the one behind the spring. Unless someone has wound up the spring, with the hinge removed and the arms in the relaxed position the spring should be able to be removed with you fingers. If you are worried, grab the end of the spring with a pair of vise grips to unhook and remove it. Do NOT try to remove the spring with the hinge attached to the hood!
54f100
26
10-04-2021 04:22 PM
zolav8
09-06-2016 02:38 PM
crewcabwannabe
10-18-2011 03:34 PM
