Cruise Control Buttons
Old Jan 15, 2013 | 10:56 AM
Archion's Avatar
Archion
Veteran: Marine Corps
With the failure rate of the early switches, collapsed foam etc, you really need to look at a later system, like well on into the 90's when they went to the switch pods to the sides of the airbags. They had real switches then. and it may serve your purposes better.
Old Jan 15, 2013 | 03:29 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Archion has a good point. My 94 Taurus has the pod mounts on each side, the on-off is left, resume, set, coast on the right.
Old Jan 15, 2013 | 04:34 PM
MavSprint's Avatar
MavSprint
Don't doubt what you're saying about the switches and I appreciate the suggestions but I already have a truck steering column and wheel that will bolt in and look right at home. The newer columns would have the additional issues of physical fit and I expect the electrical (turn signals, ignition, flashers) issues might be more work too.
Old Jan 15, 2013 | 04:52 PM
85lebaront2
Yes they will. Look at my thread on the rework on my truck.
stydel311
Jul 22, 2014 05:41 AM
02GroundPounder
Feb 13, 2011 07:54 PM
Roles
Electrical Systems/Wiring
Sep 10, 2006 09:56 PM
WOLFBAYOU
Dec 18, 2002 05:57 AM
