190k mile sparkplug
Whops, sorry, reminiscing a little, anyhow, I thnk the Opti-spark is a great design, durable as hell. Being in that community a while, it was pretty common for guys to have 160-180k on the original, and some times even the original cap & rotor. Few were well over 200k on the original Opti. Mine went almost 150k but being a police car the first almost 80k who knows how many millions of hours run time idling at the donut shop or slow cruising side streets and alleys at 10-15 mph, it was a Dallas PD so you know it had to get hella hot in the summer under that hood.
Yeah there is one, well two negatives with it, PITA to change being behind the waterpump, and expensive.
Well updating my own post, re: Techron pricing. Seems this bloke has it for a more-than-fair price: Case 6 Bottles of Chevron Techron Concentrate Plus Fuel System Cleaner 12 Oz | eBay
I would rather take a beating than tackle the vans plugs, the 5.4 is too tight for me to bother, I do know, if you don't use the recommended Motorcraft plugs, they will not last. Never reuse the boots, they are the main reason for coil pack failures, a crack causes a misfire, burning the coil out.
I have noted that gas mileage for the tank when the stuff is in the gas seems to be noticeably a bit better, but maybe that's because I usually put it in before a road trip and run the tank way down before I fill it again.
I know that BMW and Honda officially recommend Techron, so although I am opposed to most additives, I believe Techron is good stuff.
I will also note that if at all possible, I used a "top tier" fuel, which is also recommended by some mfrs. For a fuel brand to be considered top tier, it has to have a high level detergents in all grades (not just premium). In Michigan, I know Shell and Mobil are top tier in terms of major brands, and the Costco gas I usually buy has signs on the pumps that say their fuel (including regular) have 5 times the minimum required amount of detergent, so I'm assuming they are top tier. But I don't think this is a national standard for Costco gas. Here's a web page giving info on top tier fuels, again recommended by a number of car mfrs:
Top Tier Gasoline
George
ps once more I will remind Ford van owners that the only Ford plugs in danger of breaking are the 2 piece plugs used in the 3 valve engines which have NEVER BEEN USED IN FORD VANS, EVER. The 2 valve OHC V8's used in the vans did have possible issues blowing out spark plugs, more so prior to about 2005. But not breaking or stuck plugs.
I found the Pro-Guard stuff too, its definitely cheaper but with your fleet being frugal is important I'm guessing!
My deal for the Techron 6-Pack included free shipping so it comes in about $8.17 a bottle. I'll probably use it according to instructions.Will also look around locally for the top tier fuels, compare prices and where its most conveniently available. Next plug change due in about 49K miles should tell me a lot how such changes might affect things.
Thanks again!
When the mighty LT1 came out in the '94-'96 full size GMs (the ones PStruwing gushed over) the differences became absolutely zero even though many people claim has a "Corvette engine". They dont, Vettes got aluminum heads and different cams. Just more hype by the unknowing or sleezy salesman.
You could get the 350/5.7 in ANY full size, from grandpa Jims Fleetwood to aunt Millie's Roadmaster to uncle Joes Caprice/Roadmaster wagon to the 9C1 and even the Impala SS, IDENTICAL 260 (underrated) hp/330ft.lbs, same exact PCM progamming, same exact trans', same exact exhausts. The SS and 9C1 (w/LT1) came with 3.08 only (optional in civvy Caprices, Buicks and Caddys) would run identical times as one another and were a bit faster then the Buick/Caddys being lighter (and/or the gear). No "Vette engines", no "cop chips". No "FBI" chips either, yeah, I've heard that a few times!
"Stupid fast"? Compaired to what? A 4cylinder in a Sunbird? It's all relative. A Vette would absolutely kill it, 190hp/285ft.lbs in a 4000+lb vehicle is "peppy" at best but compared to any performance car is down right boring. Acceleration, it would be lucky to run high 15's at 82-83mph, top speed, maybe 130mph with a stiff tail wind.
My deal for the Techron 6-Pack included free shipping so it comes in about $8.17 a bottle. I'll probably use it according to instructions.To my knowledge those were never available to the general public, that they were simply returned to GM when their use in the field had ended. Of course the after market chip programmers of the time could outfit you for a price.
There have been and probably still are special features on vehicles intended for law enforcement duty, these features being somewhat loosely held secrets but almost certainly removed before sold to the general public.
I can't speak to the cars in question but it seems plausible to me.
Also, the cars went to auction when retired from police/fbi use.
All kinda a moot point since we were just talking about the Caprice 9C1.
I guaranty there is no mysterious "loosely" held secrets about police packages, especially the 9C1 Caprices and P71 Crown Vics. I used to belong to the EVOOA as well as various B-body (Caprice Impala SS) clubs. Everything is known of even the slightest differences between the cop and civvy versions. My aforementioned Caprice wasn't my first, just my last and it hasn't even been a year since I sold it.
Anybody that knows anything about engines and/or performance can tell you simply changing a pcm or chip WITHOUT making any mechanical changes will at best scarcely be noticeable. The LT1, without any mods will see maybe 15 hp from a reprogramming, usually 10 was more like it, again that with NO other mods. The LT1 was much more advanced in every way then the LO5. Even the current LS series, which are way more advanced then the LT1 will only see similar changes. A 10-15 hp increase in a 42-4300 lb car (with driver) is just noticeable by a gear head, average drivers wouldn't even feel it.
Hmm, should mention the Michigan State Police police vehicle testing. They are THE most respected authority on cop package vehicles. All over the nation other PD order their reports. Their tests are EASILY repeatable by people after the cars are sold at auctions, actually once in civilian hands the cars turn better times but thats due to the MSP using two people and a couple hundred extra pounds of testing equipment, point is this shows no performance changes were made.
Again, "stupid fast" is all relative, compared to a 4.3 V6 Caprice, sure it's going to be a lot faster, but overall that doesn't make it a fast car.
Now, for a minute put all the above facts aside, just think about the very basics of a pcm swap with some basic common sense.....again, FORGET all the above FACTS and knowledge I bring to the table and just think about this, hypothetically of course.....
GM supplied the car to the PD with this special cop computer right. OK so now why would the police NEED to take old PCMs out of retired cars, what would they put them into? Hmmm? Where are they getting the "standard" PCMs to put in their place? Now as we all know, departments have budgets, this pretty much (in all but the most corrupt) prevent them from buying new 'standard' PCMs at several hundred dollars each, to put back in the cars wouldn't it! Not to mention the time and labor costs to do this.
Again, just think about this last paragraph and use some common sense thinking it over.
The new cop cars come with "cop" computers, what need would there then be and just what would they be used in if the PDs took them from retired cars? WHere would the non-cop computers come from and who is paying for them?
Then you have to look at the fact that, every two years, often every year their were changes in hp, or in the fuel injection system, ignition etc. When the cars are retired between 75k and 150k the PCMs are obsolete. Why pull an old computer that's they can not use in anything?
Well there you go, a mountain of facts and info, as well as a hypothetical that would indicate the fallacy of swapping out pcm's.....but if you want to believe in 'magic' PCMs, big foot, Lochness sea monster and UFOs, it's no skin off my teeth.
.......................Well there you go, a mountain of facts and info, as well as a hypothetical that would indicate the fallacy of swapping out pcm's.....but if you want to believe in 'magic' PCMs, big foot, Lochness sea monster and UFOs, it's no skin off my teeth.
Yes there are mounds of what turn out to be misinformation about any one subject, that's in abundant evidence everyone we look on the internet. Its great you're sharing your GM info (I'm also a fan of the brand) but it doesn't need to be bashed about simply because one or two slightly disagree or have other experiences they share.
So what was the original topic here anyway? Oh yeah---- Ford spark plugs!
