1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
01 F350 4.10 or 3.73 i have 38in toyos
Old 01-15-2013, 10:35 PM
CuNmUdF250's Avatar
CuNmUdF250
CuNmUdF250 is offline
Originally Posted by redford
If you are concerned about fuel mileage, then get rid of the 38 inch tires and the 8 inch lift.
Ah Redford always the voice of reason
Old 01-15-2013, 11:56 PM
Lubbockguy1979's Avatar
Lubbockguy1979
Lubbockguy1979 is offline
I would say either 4.30 gears or 4.56 gears. That would be my suggestion for someone that dosent ever plan to pull anything heavy. The 4.30 is a stock gear ratio and could likely be sourced used in stock axles. As for mpg. You could always walk that would be 100% increase in fuel economy. But seriously anything better that 10mph in a truck that size with that much going against fuel economy would be reasonable.
Old 01-16-2013, 08:21 AM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
Originally Posted by meborder
you may see some benefit to lower gears due to the extra rotating weight of the tire combo. if your 38's weighed the same as your stock tires (they dont!) then a gear ratio close to stock would result in fuel mileage close to stock.
think how much harder the wheels are to get moving .... that tire combo weighs a TON compared to the stock combo and as such your mileage will always be lower with the big skins.
as others have said, 4.56 gets you back to the stock gearing.
you may benefit from adding a little gear, making those big tires a little easier to get rolling, thus keeping your foot out of the throttle a little on the take off and up hills.
if this were a gas motor i'd say put some 5.13's in it and be done. 5.13's would be roughly equal to 4.30's stock.
being a diesel, you may not want to go that deep. i think your best bet is somewhere between 4.56 and 5.13...... so, if it were my truck trying to achieve what you are trying to achieve .... i'd go with 4.88's and consider it a good compromise.
do what you think is right!
I love that Excel spreadsheet... Did you create it?
Old 01-16-2013, 05:34 PM
meborder's Avatar
meborder
meborder is online now
yep .... im a nerd
only thing is, as others have pointed out, the "speedometer reads" column has no real meaning for the SD's as gear ratio does not affect the speedometer, only tire size does.
i should remember to mention that when posting a printout.
it works out OK thanks!
Old 01-16-2013, 05:51 PM
redford's Avatar
redford
redford is offline
Received 1,629 Likes on 953 Posts
It's a dangerous job, but someone has to do it............
irhunter
04-24-2011 06:58 PM
JGoodish
2009 - 2014 F150
02-09-2011 07:36 AM
FordF350Baby
13
04-18-2008 06:08 PM
Studhorse_3
03-19-2007 10:42 PM
boatman83
10-13-2005 05:43 PM
Quick Reply: 01 F350 4.10 or 3.73 i have 38in toyos
