New Nose
Old Jan 11, 2013 | 04:48 PM
beersy50's Avatar
beersy50
New Nose
I have to buy an new radiator support (eventually because of rust, the whole nose) because the current one bearly holds up the fenders. I'm planning on updating the nose to the newer '92ish body style. I do realize that this will include fenders, hood, headlights, and grill. Will the '92-'94 F-350 diesal radiator support work with my current radiator or will I need to modify it? Has anyone else done this? Any tips?
Thanks for any advice or tips
Old Jan 11, 2013 | 05:41 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I did the inverse of what you wanna do. I have a 87-91 front clip on my '94 F150.
Pretty easy swap actually.
You'll need,
- fenders
- hood
- grill/lights
- cowl
- bumper (and new brackets) they do not mount the same way
- 92-97 Rad support (I think you'll also need a 92-94 specific Radiator to, but not 100% sure)
The 1992+ trucks have dual pissers in the cowl for washer fluid, so you'll also need to add a T to your single hose.
Otherwise it's a pretty direct bolt in play thing.
And just a tip for removal and installing your fenders,
Don't forget the 1 bolt on each side, you need to open the door and go from the open side of the door to access it. Don't forget to reinstall that bolt on the new fenders.
Old Jan 11, 2013 | 06:56 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Might want to research how to remove the 92-96 headlight bezels too. It can be a stumper the first time! Youtube has some how-to's
Old Jan 12, 2013 | 07:13 AM
beersy50's Avatar
beersy50
I do body work for a living so the actual process of swaping the parts is not an issue for me. My main concern was buying the right peices of the puzzle so it will fit together with out duck tape an bubble gum. I have an almost new radiator so I was hoping to get a support that used the same radiator an would except the newer headlights an grill.
jethrodean
Nov 2, 2017 09:31 PM
MikeB 88
1983 - 2012 Ranger & B-Series
Dec 3, 2012 07:42 AM
waynaferd
Mar 23, 2009 08:30 PM
Fordtuff4x4
Aug 23, 2005 10:00 PM
Fritolay
Mar 24, 2004 05:05 PM
