Difference between 2000-2004 brake pads
Old Jan 10, 2013 | 08:36 PM
petrokiller's Avatar
petrokiller
Ok I just swapped a caliper out on friends 04 f250 6.0.
What is with those pesky little wire springy things under/connecting the pads.
Took me and another guy like 15 mins to get the dadgum pads in.
Anyway does my 2000 have those too??
Could I have just left them off??
Thanks,
The parts store epidodes with casting probs is another story.
Old Jan 11, 2013 | 07:12 AM
petrokiller
Guess the silence tells me ours doesn't have the wire holders.
Old Jan 11, 2013 | 07:20 AM
gbroehl1's Avatar
gbroehl1
My 01 has them. When I went to EBC pads the holes were there but the springs were not included and one of mine was broken. I wasn't about to spend 10-20 on a rebuilt kit I only needed for the springs so I drive without one. They are there to help the pads pull away from the rotors to elongate life a bit. And yes, they are a pain to install
Old Jan 11, 2013 | 10:44 PM
petrokiller
Thank you Greg! We figured it had to be some afterthought of Ford.
My 2000 has the exact same caliper part number as his 04.
Take Care
Brad
Old Jan 12, 2013 | 07:03 AM
tjc transport's Avatar
tjc transport
i ain't rite
anti rattle clips. they are not needed, but you will get pad rattle without them
Old Jan 12, 2013 | 08:04 AM
jeffreyt's Avatar
jeffreyt
Yeah, I usually throw them out with the first change. Huge PITA with very little if any benefit. I don't notice any rattle.
Old Jan 12, 2013 | 08:21 AM
snakedoc's Avatar
snakedoc
i use them never have much trouble with them.
Old Jan 12, 2013 | 08:39 AM
mueckster's Avatar
mueckster
x2...No problems here either.
Old Jan 12, 2013 | 10:12 AM
kawcrasher's Avatar
kawcrasher
Sounds like you pulled the whole caliper and bracket together. They are no problem if you pull the caliper off the bracket.
Old Jan 12, 2013 | 08:52 PM
Pitcrw6's Avatar
Pitcrw6
Them things are a PITA. Took me about 30 min each caliper by myself. I must of said every word in the book to trying to get them on.
Old Jan 12, 2013 | 10:55 PM
lartross's Avatar
lartross
I vaguely remember someone saying something about how they're somewhat more important on the front than the rear, so when I did my brakes, I ordered some extra springs and installed them. They were fairly cheap and if they help, why not?
Old Jan 13, 2013 | 03:57 AM
Diesel Submariner's Avatar
Diesel Submariner
Bend The CLIPS
G'day Fellas,
Just grab the little right hand bend at the end of the wire clip with a pair of pliers. Slightly bend that tip out a little and slip them into the little holes in the pad backing plate. It will grip in there much better and not keep popping out .
Works every time for me .
Cheers,
Reg
TNT
Sep 17, 2021 08:14 AM
07-150
2004 - 2008 F150
17
Oct 17, 2011 01:38 PM
tcparry
2004 - 2008 F150
Sep 21, 2005 07:51 PM
1madison
1997 - 2003 F150
Dec 8, 2001 07:48 PM
