RABS Code 4
Old Jan 10, 2013 | 02:21 PM
wag53's Avatar
wag53
RABS Code 4
Hello all, need some help with my '93 ext cab 150. Have been getting an ABS light and brake light. Seems to be random, truck will run one day without lights then next time out lights will come on after several stops. There appears to be no difference in the brakes. Pulled the codes and got code 4, went through all the wiring and found no defect. The Chilton and Haynes say bad RABS HCU valve but I'm too cheap to buy a new one for $200. Is there any way to rebuild it? Also I looked on another forum and a guy said he removed large nut on HCU valve and took the spring to fix his similar problem, is this a good idea?
Old Jan 10, 2013 | 03:16 PM
rla2005's Avatar
rla2005
Some good RABS Code 4 info here: RABS code 4 - what next? - FSB Forums
Old Jan 16, 2013 | 08:06 PM
wag53's Avatar
wag53
RABS code 4
Did all the electrical checks and found nothing, but pulled drums to see if anything was suspicious there and found that driver's side wheel cyl was leaking only slightly. Flushed brake system and leak got way worse so replaced that wheel cyl. then noticed that e-brake cable on pass side was not releasing, had to replace cable. Now no ABS light and only code 16 (all ok) I guess code 4 does not just mean electrical problem.
Old Jan 17, 2013 | 06:42 AM
rla2005's Avatar
rla2005
Glad you found it
larue2000
Sep 16, 2013 07:12 AM
whiteaddiction
Sep 15, 2009 12:20 AM
ranger714
Aerostar
Mar 29, 2007 01:03 AM
SPELLY F150
1997 - 2003 F150
Nov 14, 2006 12:55 AM
