fuel pump connector low pressure
1989 bronco 5.0 5 speed
I replaced the fuel pump in the tank last fall or fall of 2011 and recently I had an issue. I got off work and went to start the truck up and would not start. did not hear the rear pump. I checked the relay and it was clicking like it should.
I got it towed home.
I get it in the garage and use my snap on 36" extension and tap the connector on top of the fuel pump through the passenger rear fender. starts right up. I checked it several times to confirm that is the problem.
so my question is now, do I cut a hole in the floor to pull the plug and put some dielectric grease in the connector or ??? the tank is 90% full and dad had arm surgery a month ago so he can't help.
I was at work a few days prior to this washing the truck very thoroughly and spraying the underside to get the sand out so maybe the water froze pushing the connector up? did not have any issues same day or the 2 days after. happened same day I put for sale signs in the window
If you are going to sell the truck, why fix it?
Now if you are going to keep it, making repairs to the connectors
sound like a good idea.
I donʻt have issues with my tank right now, but it sounds like a good
idea putting an access hole in the cargo area.
Dropping the tank is mostly a one person job, although having another
set of hands does help.
When I replaced the float in the FSB tank, I gave 20 gallons of gas
away to a neighbor since I had no place to store all that gas.
Jymmm
1997-2006 Expedition & Navigator
21
04-03-2019 12:52 AM
