No start 460
Old Jan 9, 2013 | 05:46 PM
71'3604speed's Avatar
71'3604speed
No start 460
I have an 89 f250 and it just quit one me. I was driving and it was like the key was shut off. I checked the timing chain and that's good cause the rotor spins. I replaced the Tfi module and the EEC relay. Still nothing. No spark. Any ideas?
Old Jan 9, 2013 | 06:09 PM
fdude64's Avatar
fdude64
is the coil getting power? is there spark out of coil?
Old Jan 9, 2013 | 07:21 PM
71'3604speed
There is no power getting to the coil and no spark coming out of it
Old Jan 9, 2013 | 07:26 PM
rla2005's Avatar
rla2005
If the White/Light Blue has no power with the key in the Start/Run position check fuse link D:
If you find other systems on the truck have no power as well check fuse link M
Old Jan 9, 2013 | 10:24 PM
71'3604speed
So if i am reading the diagram right there is a 20 amp inline fuse on the white\ light blue wire coming out of the distributor?
Am I reading this right?
Old Jan 9, 2013 | 10:41 PM
rla2005's Avatar
rla2005
That is how I read that diagram as well.
Old Jan 9, 2013 | 10:46 PM
71'3604speed
ok i believe i found it. it is a little black square lookin deal with two blades. It tested good so back to square one
Old Jan 10, 2013 | 04:05 AM
rla2005's Avatar
rla2005
Fuse link D has a blue wire leading to it. Most fuse links are located on the starter solenoid mounted on the passenger side fender well.
Similar to this:
If you are getting power into and out of the fuse link then you need to trace the White/Light Blue wire over to the coil.
Old Jan 11, 2013 | 07:24 AM
subford's Avatar
subford
That is not 20 AMP, that is 20 gauge fuse link. Big difference.
Fuse link "D" is on the drivers side of the engine compartment.
Old Jan 11, 2013 | 08:00 AM
rla2005's Avatar
rla2005
Would you happen to have a photo of the location of Fuse link D?
Old Jan 11, 2013 | 09:36 AM
subford's Avatar
subford
No I do not. I have one for the 89 van but would think they would be different but they may be the same.
The 1989 van drivers side fuse links (the truck may be the same):
Old Jan 16, 2013 | 08:46 PM
fdude64's Avatar
fdude64
have you checked for codes? my 460 did the same thing and I got pip sensor fail code 211 going to replace distributor sat
Pigpendirtface08
May 21, 2017 07:14 PM
copuntryboy
1997 - 2003 F150
Apr 20, 2012 10:32 PM
justin90gsx
13
Mar 9, 2011 08:43 PM
davidj7479
13
Mar 19, 2008 04:53 AM
avenueofthesun
Electrical Systems/Wiring
Apr 26, 2006 12:13 PM
