well having fuel issues again with the the 74. running rich dying for no reason. i stuck a new fuel pump on just to get that out of the way. be honest i have never taken a carb all the way apart before. so here we go. i got a few pictures taken but not many. wish me luck folks.
A really good trick that a lot of folks here on FTE use is to buy a couple of boxes of sandwich bags and use them to hold your parts.
I use a sharpie marker to mark the bag so I know exactly what's inside. The best part is, if you write neatly on the bag, you can cross out old/empty bag's writing and reuse them more other parts later.
On my motorcycle, I probably used only 10 baggies to store everything I needed because I worked in sections. By the end of my motorcycle endeavors, I had roughly 10 baggies, covered in black marker - and each bag was still legible/readable.
need to figure out what i did. wont even idle right now. i think i may have put the choke back togther wrong. does any one have a picture of how the carb linkage goes back togther on a motorcraft 2100?
