1965 351w install
1965 351w install
Hi, guy's i have 2 65, shorties & in the one i want to install a 351w engine & C-4 trans. Has any one installed this set up & what parts mount wise would i need to get , or do i have to fab. every thing ? Engine & trans. install or point me in the right direction ... Thanks' ,Don Cross
1965 F100/250 4WD; 1965/66 F350; 1966 F250 4WD use a similar 3 point engine mounting system as 1961/64's, and the same rubber insulators.
The FE bell is specific to these trucks as it has two 'ears' on it.
Rear per side: "Donut" rubber insulator located below crossmember, rectangular steel/rubber insulator located above, between crossmember and ear of bell.
Bolt passes thru lower/upper insulators, then thru ear on bell. Nut/washer secures in place.
Front: L shaped bracket bolts to block. Donut below crossmember, rectanglar steel/rubber insulator above crossmember.
Bolt passes thru L shaped bracket, upper/lower insulators, nut/washer secures in place.
You're doing just fine.
It wasn't your fault in the other thread (park brake lever spring), it was mine, because I didn't look up the spring applications in the text, just relied on the catalog pic which is wrong.
It's not your fault inre to arbuckle3 either, because he failed to list all the pertinent details when he typed i have a 65 with a 352 in it.
Where is there any mention of 4WD? No see um.
77f100guy
03-20-2022 07:16 PM
Uni Moe
37
08-11-2017 06:44 PM
Robert R
01-13-2005 07:57 PM
x_usmc_x
01-17-2004 11:20 PM
