Steering wander
Old Jan 13, 2013 | 07:18 PM
85e150's Avatar
85e150
Originally Posted by arno
Not eletronically controlled, correct. Just looking for options to keep the wheels going straight instead of pulling the wheel in you hand. Bigger tires = more leverage on the entire system.
Does it pull to one side? It should run fairly straight with your hand off the wheel. It should return to center from a turn also.
If it pulls to one side or the other, it is an alignment issue. Ditto if it won't return to center.
Old Jan 13, 2013 | 07:22 PM
khadma's Avatar
khadma
Carpenter Local 745
No, apparently he really needs a steering stabilizer to fix it.
Old Jan 13, 2013 | 07:47 PM
arno's Avatar
arno
None of the above, works just fine until you get off road or are on a rutted road or heavy grooves.
Old Jan 13, 2013 | 07:54 PM
04XLTRUNNER's Avatar
04XLTRUNNER
That's just the nature of the beast. Wide tires=pull offroad. Especially on ruts and grooves
Old Jan 13, 2013 | 07:55 PM
khadma's Avatar
khadma
Carpenter Local 745
I was going to remove this subscription because
It was getting lame, but arno, list what parts you have.
Suspension lift
Rims
Tires
Shocks
You are not giving anyone usefull information.
Old Jan 13, 2013 | 07:58 PM
04XLTRUNNER
I agree. It would be nice to know what you actually have to give you some better advice and help.
Old Jan 13, 2013 | 08:12 PM
arno's Avatar
arno
Lame, copy that.
Old Jan 13, 2013 | 08:15 PM
04XLTRUNNER
Lame, copy that.
So your not goin to give us any more information on your truck? We are trying to help and if you want that help then you have to answer a few questions.
Twonky
Sep 11, 2017 08:51 AM
lizardking1
Nov 21, 2015 10:51 AM
X_Hemi_Guy
Apr 10, 2007 12:51 PM
