Frame bends...under hard braking!?
Old Jan 5, 2013 | 06:40 PM
custom1106's Avatar
custom1106
Drama with my '82 Bronco
Yeah...I couldn't believe it. I have an issue with a pull while braking. After replacing pretty much all of the hydraulics ie: calipers, hoses, wheel cylinders...I still have a brake pull. But...the wheel doesn't move when the pull happens.
So I decided to strap a video camera to the bottom of my rig to see what's going on. I thought it may have been a radius arm bushing acting up, but those are a newer poly set.
Its the frame flexing!
Every time I hit the brakes hard I could see the frame flexing in where the radius arm bracket attaches allowing the left "I" beam to move backwards and pull the truck to the left. This bronco is a rust free desert rig with no frame cracks.
Anybody seen this before? I've tried everything to fix this issue with new bushings, pretty much all new brake system and alignments...I never thought it would be a frame issue! Any suggestions?
Old Jan 5, 2013 | 06:50 PM
Franklin2's Avatar
Franklin2
Have any drivetrain swaps been done on this vehicle? If so, were the upper crossmembers put back in place where the tranny crossmember is located?
This is not a common problem, so something is wrong somewhere. I would check for loose frame rivets on the crossmembers also. From your post, I am assuming the frame is "caving in" at the top or twisting?
Old Jan 5, 2013 | 07:56 PM
Gary Lewis's Avatar
Gary Lewis
Subscribed. I gotta see how this turns out.
Old Jan 5, 2013 | 08:36 PM
86fordtruck's Avatar
86fordtruck
Me, too. I agree with Franklin2. This is very odd. Are the diagonals on the trans crossmember present? When I replaced the clutch on my truck a few years ago, a guy at the MWR Auto Shop suggested I just leave them out, saying most folks don't put them back in. I did replace them, though. In retrospect, it was a good decision, because their abscencec could allow the frame to flex in that area. Also, as Franklin2 mentioned, loose rivets might also allow crossmembers to loosen and allow flex, but that would sure be unlikely. Good luck getting this thing fixed.
Old Jan 5, 2013 | 08:37 PM
custom1106's Avatar
custom1106
All original drivetrain. It bows in at the bottom of the frame rail where the radius arm mount is. Its making it kind of twist from the bottom. Ill have to throw it up on a rack at work and check the fastners in that area. I had loose rivets in the steering box area on an '85 I had.
Old Jan 5, 2013 | 10:20 PM
81ChopTop's Avatar
81ChopTop
If you have video of this, can you post it on youtube or something so we can all see it?
Old Jan 5, 2013 | 10:32 PM
1983F1503004x4's Avatar
1983F1503004x4
I guess it's safe to say you can lock up all four wheels?
This is definitely a strange issue!
The radius arm itself isn't bent, or the rivets holding the radius arm bracket to the frame aren't loose, are they? If the rivets holding the radius arm bracket have come loose, grind off the heads, drive 'em out, and stick in no less than quality grade 8 bolts and nuts. Do them one at a time and the radius arm bracket won't even have to move.
Old Jan 5, 2013 | 11:46 PM
JayzDaddy's Avatar
JayzDaddy
If all else fails you could box it.
Old Jan 6, 2013 | 01:27 AM
joshofalltrades's Avatar
joshofalltrades
might be time to add a crossmember right behind the radius arm brackets - a piece of 4" channel iron should do, i would have it sit under the frame rails with the open side down
Old Jan 6, 2013 | 02:39 AM
SideWinder4.9l's Avatar
SideWinder4.9l
Subscribing
Old Jan 6, 2013 | 08:08 AM
Franklin2's Avatar
Franklin2
Like I said this is not a common problem, so something has to be wrong. I would also eyeball the radius arm bracket for being plumb compared to the other side. I believe from memory the radius arm should be pretty much underneath the frame correct? What if the radius arm bracket was slightly bent and that put the radius arm mounting out beyond the bottom of the frame. That would give it some leverage to put pressure on the frame.
The frame is very strong against forces straight up and down. It's not very strong as far as resisting twisting, and that's the reason for the crossmembers being tied to the top and bottom of the frame.
If you notice, the rear springs are mounted on the outside of the frame using brackets. That would normally be a no-no, but they also have crossmembers in the same area to hold the frame straight up and down. If they weren't there, the outside mounted spring perches would want to cave the frame in at the top when weight was put in the truck.
I can't remember if there are crossmembers in the radius arm bracket area or not.
Old Jan 7, 2013 | 11:08 PM
custom1106's Avatar
custom1106
Well got it up on a rack at work today and went at it with a pry bar checking out rivets and cross members, everything checked out. So I decided to do an alignment...myself! I'm a parts counterman at a dealer, but used to be a tech. I had never done alignments myself since I was a electrical guy, I always traded electrical jobs for alignments. So I had a buddy in the shop show me how to set the machine up and did the alignment myself.
Just about everything was out of whack. Now the thing goes down the road really good, with no brake pull! It took me quite a while to get everything adjusted perfect. Handles way better too! I can see why a flat rate tech wouldnt want to spend too much time lining up one of these things.
Thanks for the help/suggestions...I really appreciate it. I never thought an alignment issue would cause something like this.
Old Jan 7, 2013 | 11:18 PM
Gary Lewis's Avatar
Gary Lewis
Now the frame doesn't flex under braking? How far out was the alignment?
Old Jan 7, 2013 | 11:20 PM
custom1106's Avatar
custom1106
Way out...like off the scale. I had a friend of a friend do the last alignment a couple of months ago. I had some bushing issues that I took care of then had it realigned.
Old Jan 8, 2013 | 06:21 AM
bashby's Avatar
bashby
Was it just the toe way out or did you adjust caster and camber also?
