engine stand oil pressure ck
Old Jan 5, 2013 | 04:11 PM
rocky71's Avatar
rocky71
engine on stand, finishing up overhaul, it would be nice to put the specialty tool down the distributor hole, spin the pump and ck pres and topside circulation, but on this 1986 w/460 eng I would have to put an oil filter to the block to hold pressure but i would need a adaptor/male threads at both ends and then screw on an oil filter.
Does one exit or other options?
Old Jan 5, 2013 | 04:21 PM
rocky71's Avatar
rocky71
in other words on my f250 truck......maybe old ford sedans back in the 60's 70' etc did not have oil cooler hook up adapter and only screwed oil filter directly to the blocks male threaded
Old Jan 5, 2013 | 04:33 PM
CountryBumkin's Avatar
CountryBumkin
A very common item. see FORD 7.5L/460 Parts and Accessories - SummitRacing.com
Old Jan 6, 2013 | 03:21 AM
81ChopTop's Avatar
81ChopTop
By what's written in red, it sounds like you need the threaded adapter that screws into the block?
This guy?
If that's the case, you'll have to get one out of another block, but usually the threads are wrecked taking them out because of how tight they are put in.
Old Jan 6, 2013 | 04:17 AM
rocky71's Avatar
rocky71
ok, i will ck with the salvage yard and just remembered the ford dealer here in this small town has a book for old ford numbers
djmac
Jun 14, 2007 01:46 AM
barnfresh
Nov 7, 2004 06:29 PM
51dueller
Flathead V8 & Flathead 6
May 4, 2004 01:04 PM
Brian460
Jul 20, 2002 02:00 AM
