futuras
Old Jan 5, 2013 | 10:01 AM
heyranch's Avatar
heyranch
futuras
got a '96 F250 with a 460. When I start it cold it goes off fast idle too soon but will go back to fast idle when I put it in a drive gear. Put it back in nuteral or park and it slows down again. Any thoughts? Thanks
Old Jan 6, 2013 | 04:56 PM
rla2005's Avatar
rla2005
Have you checked for codes as asked in your original thread ( https://www.ford-trucks.com/forums/1212250-futuras.html) ?
Old Jan 7, 2013 | 11:10 AM
heyranch's Avatar
heyranch
Yes, 411 and 412
Old Jan 7, 2013 | 11:21 AM
rla2005's Avatar
rla2005
Originally Posted by heyranch
Yes, 411 and 412
DTC 411= Cannot control rpm during KOER low RPM check
DTC 412= Cannot control rpm during KOER high RPM check
Both of those codes are from the Key On Engine Running (KOER) tests. What codes do you get on the Key On Engine Off (KOEO) and Continuous Memory (CM) checks?
Old Jan 7, 2013 | 01:17 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
futuras????
Old Jan 7, 2013 | 01:57 PM
heyranch's Avatar
heyranch
Thanks for the reply. Unfortunately my battery went out right after that and I lost all codes. Do the codes I posted tell anything?
White 97 xlt's Avatar
White 97 xlt
Originally Posted by DPDISXR4Ti
futuras????
I'm with you and about everyone else around here... What does futuras (whatever the hell that is) mean or have to do with this thread?
Curiosity KO'ed the feline!!
Old Jan 7, 2013 | 01:58 PM
White 97 xlt
Check post #4!!!
Old Jan 7, 2013 | 02:03 PM
heyranch's Avatar
heyranch
dpdisxruti
Your handle isdpdisxruti and you and you are confused by futuras?
Old Jan 7, 2013 | 02:10 PM
White 97 xlt
If he used that in the SUBJECT line of a post it WOULD be confusing!!!!
Old Jan 7, 2013 | 03:23 PM
rla2005's Avatar
rla2005
Those codes do not really mean much at this point. It does indicate the computer cannot control the idle RPM via the IAC but this mimics what your initial problem statement is.
A common cause of those codes are a sticking/faulty IAC, vacuum leaks or a faulty PCM (computer). The last one listed is a very rare cause.
It would be more beneficial to run the KOEO tests and CM display.
Old Jan 7, 2013 | 04:37 PM
heyranch's Avatar
heyranch
Thanks for your reply. I will run a check like you say and maybe that will tell me something . Thanks again
RichInTN
Jun 17, 2016 10:06 PM
andysam
Mar 26, 2014 05:18 PM
Beaven
Jun 21, 2012 07:50 AM
gpachner
Apr 2, 2002 07:56 AM
