Can anyone tell me what this is? I think it is OEM as it has a Body Builder tag on it. In line with the gas pedal in the place where you might install a break controller module.
But it's visible from the drivers seat and mounted at the bottom of the fuse panel cover? Others I have seen were always up under the dash and visually concealed from the passengers. This is mounted so you can access it while driving.
OBD II ports were standard on all 96 and newer OBD II compliant vehicles. The connector must be, by law, within 2 ft of the steering wheel and accessible from the passenger compartment.
