Temperature Gauge
Old Jan 10, 2013 | 11:32 PM
hiball3985's Avatar
hiball3985
Originally Posted by CougarJohn
I am an electrical engineer. I cannot come up with any sensible reason wherin a coil wire in a high impedance circuit could couple into a dc circuit like an electrical gauge. Certainly not to make the gauges go nuts or with the temperature dependance that you describe.
Do you hear any engine-rev-dependent noise in your radio?
Do any other gauges flare when your temperature gauges flare? (CVR).
As above, I suggest you replace the sender.
I'll have to agree. that's a new electrical theory I have never heard about or experienced
Old Jan 11, 2013 | 06:53 PM
NS70250's Avatar
NS70250
haha, my electrical knowledge is minimal at best.
the gauge worked fine until about a week or two ago. i hadn't really had much time to look into it. it previously warmed up after about 10 minutes of driving, and would sit within the normal range.
all of a sudden one day i watched it warm up and then just continue moving until pegged. it did that for about a week. it would sometimes drop back to normal when the RPM's were higher, but then return to pegged.
i was looking around and noticed the coil wire sitting on top of the sending wire. i moved it away and now when it warms up it just gets to the first edge of the normal zone. it may well be coincidence. all the other gauges continue to function normally.
i'm going to see what happens when i ground the wire to the engine, and probably get a new sending unit because everyone says they are an inexpensive replacement.
Old Jan 11, 2013 | 07:08 PM
hiball3985's Avatar
hiball3985
A sending unit won't bankrupt you . The only other time I have seen a gauge do that is when the coolant/water level gets so low that you get steam in the voids and that will send the gauge crazy too.
Senor del Taco
Nov 17, 2011 08:11 PM
Tom D
Mar 3, 2009 06:47 PM
MrRogers
Nov 16, 2007 05:07 PM
JKK
Mar 5, 2006 07:25 PM
goodolefletch
1983 - 2012 Ranger & B-Series
Dec 3, 2003 12:58 PM
