Parasitic draw... too much?
Old Jan 4, 2013 | 07:17 PM
potshot's Avatar
potshot
Trailering
This is on my stock, 2002 F-150 XL Sport (smaller V8)....
The first aftermarket item on this 10 year old truck is a low end Alpine stereo. Good times.
I had Best Buy install the thing. Maybe not so good times because the battery was dead the next morning.
I wanted to see what kind of draw I had while everything else was turned off so I broke out my little meter to see what I could see,
I'm thinking this is a little high. I have my meter in series on my negative cable and don't see any change on the reading when I pull the fuse for the radio.
Thoughts?
Old Jan 4, 2013 | 08:03 PM
SteveC7010's Avatar
SteveC7010
I'd take it back and have them fix it. After market radios, if properly installed, should not draw any current at all when the truck is not in run/accessory mode. I just moved my JVC HD radio into the new truck. I used the same power and run/accessory lines as the factory radio by purchasing and installing an adapter harness. It was a simple and straight forward job.
Old Jan 4, 2013 | 08:22 PM
Franklin2's Avatar
Franklin2
All radios with a memory for the radio stations will have some draw. The highest draw that is usually considered ok(for the complete vehicle) is .07 amps or 70ma. Your reading is high but; You have to be careful with your type truck. The newer trucks have all the electronics and battery saver functions, and they will keep certain parts of the truck powered up for awhile after the key is pulled and the door is shut. A guy who messes with these things says the manual calls for you to wait up to 40 minutes before checking for a draw. It sounds excessive to me, but I would certainly wait a little while before I took a reading.
Old Jan 4, 2013 | 08:25 PM
projectSHO89's Avatar
projectSHO89
That's what the book says although the battery saver relay usually times out in 30-35 minutes.
If you do not wait the appropriate time, you'll end up chasing a non-existent gremlin.
After the timeout, you'll probably see a peak draw of 50-70 mA.
jyarosz
2009 - 2014 F150
18
Jul 8, 2014 07:56 AM
hillbilly1025
Escape & Escape Hybrid
Jan 22, 2012 11:59 AM
Alex Penton
Jun 26, 2003 08:03 AM
FreakinOldGuy
Electrical Systems/Wiring
May 21, 2003 09:59 PM
78f250
Nov 19, 2001 07:18 AM
