Does anyone recognize this blower motor
I dont like it cause of the heat and I am assuming that eventually its gonna blow anyway so I will need to find a 12 volt at the scrapyard that I can modify to work within my original Ford Majic air heater ( circa 1952 )
Does anyone recognize this at all so that I may have an idea of what might work before I start tearing blower housings apart.
Just to clarify if this looks like the blower motor in your 1983 F-150 than that will at least give me a place to start. Thanks
I used a resistor on my wiper motor on the 53, but I did retro fit a 12v motor into the fan housing. I want to say it was a old motor off a scrapped out 79 Granada I had, but I can't be for sure.
I can tell you for sure the resistor for the wiper motor does not work well. The resistor drops the voltage down, but the amount of drop depends on the current flow. On a blower motor it would probably work, but on the wiper motor, with a dry windshield, the motor has a lot of drag on it, so it draws a lot of current through the resistor, so the voltage has a large drop, and the motor barely moves the wipers. When the windshield is wet, there is less drag, so there is less current flowing to the motor, so there is less voltage drop, so your wipers are whipping back and forth too fast. It's not a good thing.
Ill get the fan motor, just like you did, Ill have to go do some digging tomm at the salvage place
I think I will stop by a place this A.M that does electric motor work and see if they can do anything to convert these to twelve volt and what they charge.
Is it the number of windings they have to alter to convert to 12 volt, is that correct?
One option for my 53 was to get a 56 wiper motor, but they are not cheap either. I think 56 is when they went to 12v. I don't know if it would work on a earlier model like yours though.
I went to three different electric shops and got laughed at when mentioned if they could make the conversion.
That is too bad! Sometimes one just has to keep trying until you find a place where someone [usually an older experienced person] really cares. This is not unlike the experiences often reported regarding people behind the counter at the various automotive parts stores... some of the employees are GREAT, but some simply look at the computer.
This may be the answer...
Check this link and read about the 12/6 Battery. It is claimed to make possible for one to convert a 6 volt system to 12 volts and tap off 6 volts for your accessories. It is available in group sizes and is to be used with 12 volt charging systems.
The battery appears to have 3 terminals. The outer 2 terminals would provide 12 volts and the one in the middle would provide 6 volts.
Check the price and determine if economically feasible?
Antique Auto Battery - Accessories
I have lived in Fl, Tampa, Sarasota area since 1987 or so and it was not until just recently ( last couple of months ) that I found a hardware store the likes of which I had not seen since I was a younger man. Its about an hour away and H.D has now moved into the area and from what I have heard ( I used to work out there until recently ) they are in a position to close its doors for good.
Only thing left after this will be the wiper motor.
Thanks for the effort though
( as was the original 6 volt motor ) but the fins within the cage are not going in the right direction so there is not as much airflow as I find when I mount the cage this way
I have spent a good amount of time reading old posts this afternoon that have been made concerning replacement motors to fit in these specific Ford units ( 51-52 ) and as far as I have read they do not exist so I will modify my case to fit the motor.
I am not up on all the stuff they have out now, but when I was looking for alternatives, I was eyeballing this setup they use for hot rods and other vehicles. The motor actually mounts anywhere, usually down near the kickpanel, and it has a cable that moves back and forth and at each wiper spindle it has a rack and pinion setup to turn the wiper arms. It was fairly expensive back then, I don't know if has come down now or not.
P.S. These motors have brushes, so you may not be able to do the above. If you can take the motor windings out and turn them around, it will change the direction. I think you get the idea though if you can figure out how to turn something around inside.
