Restoring an '81 F150 and heater cable is attached to controls on console w/ plastic fitting that keeps breaking. Has anyone dealt w/ this & come up w/ a solution?
I'm also considering putting more modern controls in & wondered if anyone has experience doing this?
Appreciate any suggestions.
It isn't just on Ford trucks. If you are talking about the little tab on the casing that snaps in to the controls you can use a zip tie to hold it in. At worst case drill a small hole in the control to pass it through. No one can see it once it's done and it works fine.
The control arm is actually attached to the wire cable & the plastic fitting is molded to the cable sleeve & is the mounting bracket bolted to the frame under the dash.
The plastic mounting can't withstand the force of sliding the cable in & out of the sleeve & never lasts long before it breaks.
You are right tho, I just need to modify the cable mounting. Its behind the dash so doesn't need to be pretty...just practical.
The heater controls on the 1980-1982's are different to 1983-1984-1985/1986.
It also goes by engine, Factory A/C, Deluxe Dealer A/C, High Output Heater, standard heater, or if the truck has two tanks or not.
On the 1981, is it the plastic control section itself or the little tab on the cable itself that keeps breaking?
If it's the control, you might find one in the wrecking yard. Look in the econoline vans as well. You will have to keep around the same year 1980-1982. Or you might be able to swap complete cable and control assymblies with a 1983-up as one unit.
Probably not, the 92-95 maybe, 96/7 uses a double cable (pulls both ways). I don't have both in front of me, but some of the major differences are: 80-91 use a lever type blower switch, 92-96/7 is rotary, same for mode, wiring and vacuum connections are different, 80-86 tank selector is in the heater/AC control panel, 87-91 left side of dash under the cluster. 92-96/7 left side of cluster near the headlight switch. Physical size and mounts are different too. You could probably do it, but you would need a bunch of fabrication.
You might have a problem in the other end making the cable(s) hard to move. I would check that out too.
I just went through this in my '87 (non-AC)
Bill is right, just use some zip ties and drill holes if needed.
Lubing the cable (wire) helped a lot by reducing friction inside the sleeve.
I own a motorcycle so I have a little clamp on cable luber that accepts the straw from a can of Cable Life.
The cables would need to be swapped, on Non A/C as well.
I was thinking of upgrading to a 1983/1986 control on my 1981 because cables are so hard to get ahold of for the 1980-1982. Even so far as to drill the face plate off the control and screw in the 1981 face plate so it looks year correct.
I still might if my temp cable breaks or sticks... again...
What about the vacuum connections? I know the A/C controls have a completely different connector between the early and late style of control, although the connector behind the glove box is the same so you can swap controls if you get that piece - as well as the cables. But, what about the non-A/C later controls - did they use the same vacuum connection at the control that the later A/C controls did?
