Recently replaced fuel filter. Truck starts fine and will idle all day if I let it. Once I attempt to drive it the truck will die. Need ideas on troubleshooting. I have a 6.0 but I am weak on 7.3 knowledge. Thank you
I had a similar problem. Pretty much my whole fuel system decide to crap out all at once. Though i don't think thats your problem. Just don't drive it too much when it does that or you may end up killing the injection pump.
But, the last problem i fixed was fuel starvation after i got the truck to start and not run like butt. I had a hard time with this one. Normally no one suspects the fuel supply and return lines.
I bypassed the fuel selector valve, and the metal hard lines, and also ran a new return line. Works good now.
Does your fuel filter light come on a few minutes before it craps out when driving?
i had a similar problem if i gave mine throttle it would crap out. i ran some tranny fluid in the filter and it cleared it up. truck runs real nice now.
ATF or Powerservice in the fuel filter. Run the engine until the pump is full, shut it off, let it sit.
Many report everything works as it should afterwards.
i would guess a bad lift pump or a leak somewhere before it, starving the engine for fuel. the IP can suck enough to get by with a bad lift pump if you're lucky, but won't run well or consistently.
as the others said, check for pressure and/or flow at the schrader valve on the fuel filter housing while its idling. IIRC it should have 5-7PSI and a significant flow, which i'm not sure but i think if might be like a pint in 30 seconds... no, that sounds too small to me - i'll let someone else get detail on that. in any case, you should have a very significant flow from there
