gauges?
Old Jan 2, 2013 | 07:09 PM
1969furd's Avatar
1969furd
gauges?
is there a singe screen kinda like a programmer that will show me real time voltage, water temp and oil pressure, without buying a tuner?
Old Jan 2, 2013 | 07:13 PM
danorules's Avatar
danorules
Some scanners will give you real time readings.
Old Jan 2, 2013 | 07:20 PM
1969furd's Avatar
1969furd
do you have a suggestion? batteyr went and the batteyr gauge never moved, alt is now going out the batteyr light comes on, but the "gauge" never moves
Old Jan 2, 2013 | 07:23 PM
danorules's Avatar
danorules
I went with the programmer and don't have any recommendations for a code reader. but a quick search on Ebay showed a bunch of options between $20 and $100.
Old Jan 2, 2013 | 09:51 PM
air1jpg's Avatar
air1jpg
You may want to have your alternator checked. If it is good, then have your voltage sensor checked. My battery recently went south and my battery guage indicator swung down toward the L everytime I started the engine until I installed a new battery.
Old Jan 2, 2013 | 09:53 PM
1969furd's Avatar
1969furd
well my alt is bad, headlights are dimmer (new battery installed yesterday) dash lights dimmer, so it can only be the alt right?
Old Jan 2, 2013 | 10:32 PM
air1jpg's Avatar
air1jpg
Probably, did you install the battery yourself? If not, you could have a loose or dirty connection at the battery or a bad ground somewhere.
Old Jan 2, 2013 | 10:48 PM
1969furd's Avatar
1969furd
yes i installed it myself battery connections were tight, ground on the firewall tight, far as i know the connection on the starter is tight
willyd520
Jun 27, 2019 10:59 AM
AkF250HD
Aug 1, 2012 10:31 AM
BobsF350
Jun 7, 2008 02:19 PM
BigRedSD
Jan 13, 2004 04:04 PM
bdclark
1978 - 1996 Big Bronco
Jul 21, 2003 12:47 PM
