Headers for '96 4.9?
Old Jan 2, 2013 | 06:19 PM
AndrewW's Avatar
AndrewW
I've been poking around the internet for awhile now trying to track down headers that will fit my truck, but I can't seem to locate any. Has anyone seen them or am I chasing a jack-o-lope on this one?
Old Jan 2, 2013 | 08:05 PM
pfogle's Avatar
pfogle
You're not going to find anything that flows much better than your stock EFI manifolds. They are already split into two banks of three and have pretty good flow characteristics. You might look into the HD exhaust manifold that was used in large trucks and industrial applications.
Old Jan 2, 2013 | 09:33 PM
TexasGuy001's Avatar
TexasGuy001
I'd also suggest keeping the stock split manifold.
Old Jan 2, 2013 | 09:44 PM
AndrewW's Avatar
AndrewW
There doesn't seem to be much you can do with this engine or the 2WD model.
Old Jan 2, 2013 | 09:52 PM
SideWinder4.9l's Avatar
SideWinder4.9l
Unless you have a full on "Race" engine....
Stick with OEM..
Hedman Headers has a set for about $200, from Summit Racing...
But for $200, you have have the camshaft nearly swapped out....And see TRUE gains.
Old Jan 2, 2013 | 10:08 PM
AndrewW's Avatar
AndrewW
I looked around Summit and only found the Dorman OE replacements for the front. But given the general consensus, I shall stick to OE.
Old Jan 2, 2013 | 10:48 PM
SideWinder4.9l
Only difference in the Hedman style, and the OEM ones, are;
The Hedman brand is a 1 pc unit, instead of being 4 pc
Old Jan 2, 2013 | 10:58 PM
AndrewW's Avatar
AndrewW
All the pictures I have seen for the manifolds have been one piece designs. Is the four piece stock and replacements one piece?
Old Jan 2, 2013 | 11:07 PM
SideWinder4.9l
The OEM pieces are technically just 2 pc sets-
2 of those..^
The aftermarket OE style are just that...
The Hedman units are like this-
So you can see, all you're doing is simply moving the Connector Flange lower....
Old Jan 4, 2013 | 10:50 PM
AndrewW's Avatar
AndrewW
I see. Aside from aesthetics, there is no difference really.
Old Jan 4, 2013 | 10:56 PM
SideWinder4.9l
You got it..
The only REAL gains, are, as I said...
If you're racing the thing, or have it fully "Built"
Which, I HIGHLY doubt.
Old Jan 5, 2013 | 11:00 PM
guitarist41991's Avatar
guitarist41991
clifford performance has been the only place i can find any.
Clifford Performance: 1965/96 Dual Headers 2WD/4WD Ford 240/300 Trucks
Clifford Performance: 53-0015 "6=8 HEADERS" Ford Trucks/Cars/Vans 1980-97 2&4wd nPre 1980 2 wheel drive only
Old Jan 6, 2013 | 09:07 AM
hotrod351's Avatar
hotrod351
stick with the stock manifolds. in the good old days youd see a increase because the engines had high compression. these engines are low compression and besides the split dual exhaust manifolds that come whit the 4.9 are really good.
Old Jan 6, 2013 | 10:24 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
I find this sentence in their description highly suspect...
Average gains on a stock engine are 18-22% when bolting on this header.
Someone should ask to see the dyno sheets documenting this claim.
Old Jan 6, 2013 | 04:49 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Just use the Walker 45166 2 1/2" Y-pipe, and take an 1 7/8" hole saw to ream out the crappy little hole where they weld them together.
Julian Kalamaha
Sep 25, 2018 03:26 PM
nicknault
Apr 19, 2014 09:40 PM
fordsuperduty250
Nov 2, 2012 05:38 PM
o0haco0o
18
Feb 12, 2004 02:14 PM
Like M. Fords
Nov 1, 2002 12:29 AM
