Slick 50....
Old 01-02-2013, 02:38 PM
Deer545's Avatar
Deer545
Deer545 is offline
Slick 50....
Have a 1986 carb. 300 I6, 88,000 miles. I always use good high mileage oil when I change it. (Stuff for over 75,000) The rear main seal leaks a little and was thinking of adding a additive to try to get it to maybe help out a little with the drip. Looked at "bar's leak" real main seal additive but the stuff looks like it will clog up my oil filter. I then look at slick 50 high mileage engine oil additive. It says it can slow or stop oil leaks. Anyone have any experience with either product. Also on a side note the new slick 50 products claim to have no "PTFE aka Teflon"
Old 01-02-2013, 02:52 PM
tempest411's Avatar
tempest411
tempest411 is offline
The older products for this purpose, like the CD-2 brand definitely work, but it's only temporary. They work by chemically attacking the material of the seal, making it softer and more pliable. The downside is that it will work for a while, then deteriorate rapidly. Hopefully by that time you'd be in a position to change out the seal. I've never heard of anyone using Slick 50 for the purpose of slowing down leaks.
Old 01-02-2013, 03:11 PM
Deer545's Avatar
Deer545
Deer545 is offline
The slick 50 I was looking at says "slick 50 recharged, high mileage" and on the box says "revitalizes seals to help stop oil leaks"
Old 01-02-2013, 04:02 PM
Deer545's Avatar
Deer545
Deer545 is offline
Where does everyone's oil pressure gauge read? Mine is not center, reads a little more to the low side the. Then center between the two. On start up it reads about
1/4 between center and low till warms up.
Old 01-02-2013, 05:35 PM
81ChopTop's Avatar
81ChopTop
81ChopTop is offline
I have never used the Slick50 stuff, and never plan to. I have used the Lucas brand stuff with so-so results (the engine was getting pulled and scrapped anyways, so I didn't care about it). If you were looking to just "get by" for now until you can replace the seal, may give it a try.
Question is, if the product softens seals to make them seal again, is it going to do that to all the seals so they all have to be replaced? Just something to think about.
For the oil pressure gauge, I don't think any two read the same. If you want an accurate reading, install a quality aftermarket gauge.
Old 01-02-2013, 08:34 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
88,000 is barely broke in on the 300-6.
Are you sure it's not 188,000 or 288,000...???
Oil Gauge...
Mine reads between the "m" and "a" of normal on startup, and between "n" and "o" at warm idle. At warm crusing speed, between "r" and "m".
What does this mean...? It means it's got normal oil pressure...
As long as it reads in the Normal band, then it's "supposedly" safe.
Old 01-03-2013, 06:23 AM
JayzDaddy's Avatar
JayzDaddy
JayzDaddy is offline
I personally wont use any slick 50.
My dad thought it was good stuff back in the early 90s. Put it in 3 of our vehicles. All 3 blew motors within 3 months.
Only real fix is to fix.
Old 01-03-2013, 08:36 AM
Deer545's Avatar
Deer545
Deer545 is offline
-Explorer, yes I am sure of the 88,000 miles. Got the truck from the original owner with the original title. The truck runs great and is in my opinion excellent to almost perfect condition. I dropped a lot of money into the truck to sleep better at night. This baby is my daily driver. The rear main seal drips about one-two drops of oil every day after about 100 miles of driving to work. Doesn't bother me expect for the oil stained garage. The truck was drove about 8,000 miles a year till about 1997 when it was parked till 2012 when I picked it up. I have replaced every single thing possible expect the rear main seal. I have over $3,500 just in the maintenance parts. Nothing was broke but I wanted to know for sure the truck would be is excellent mechanical condition. New shocks, ball joints, bearing, tires, fuel pump, fuel selector switch, rebuilt carb, new brake lines, new wipers, new cap and wires, plugs, and more...
Old 01-03-2013, 08:45 AM
Deer545's Avatar
Deer545
Deer545 is offline
Anyway, I guess I will just wait till I don't need the truck and fix the rear main seal. My next question is why is my oil pressure gauge not reading very high. I would say at start up it is at R and normal driving is never moves past the O. I have never seen it go past the R "half way".
Old 01-03-2013, 12:16 PM
81-F-150-Explorer
My guess, sending unit is half plugged with old oil, or the sending unit is off a little bit.
I hope you kept the good working parts. The truth of things is that a lot of the older factory parts are made better than new aftermarket junk made in china.
Old 01-03-2013, 12:25 PM
ratrace2's Avatar
ratrace2
ratrace2 is offline
Could be a number of reasons, (bad cam bearings), etc. But slick 50 is just going to change the viscosity of your oil so it won't be able to pass through that little void in your main seal.
Adding a quart of 50 weight would do the same thing. IMO.....LOL
Old 01-03-2013, 03:11 PM
1986F150six's Avatar
1986F150six
1986F150six is offline
You might just slip a piece of cardboard under the truck when parked and smile at the money you have saved... also, check the PCV valve. If stopped up or sticking, crankcase pressure build-up will cause the rear main to leak.
Old 12-11-2014, 03:06 PM
phoskins's Avatar
phoskins
phoskins is offline
My sentiments exactly.
1-2 drops of oil after driving 100 miles is not enough to bother with, in my opinion. I would just check the oil frequently.
Old 12-11-2014, 03:11 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
slick 50 is good for taking money out of your wallet. thats about it. snake oils.
Old 12-11-2014, 03:33 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Why are we resurrecting an almost-2-yo thread?
Quick Reply: Slick 50....
