AC/heater control mod
Old Jan 2, 2013 | 08:36 AM
trekbasso's Avatar
trekbasso
Okay, so a weird time of year to do this, but was simple and cheap. I spliced into the red vacuum line, and I don't have heat except heater position on down. I expected the left side of dial to be cool, but thought the heater/vent position would still be warm.?? Did I splice the wrong vacuum line? If I read correctly, the white line will do only the max ac position, and I was hoping for cooler vent and regular ac also.
Thanks.
Old Jan 2, 2013 | 09:04 AM
Supercab's Avatar
Supercab
I did the RED line on mine a few years back and everything on the LEFT side of the OFF position is COLD, and non-adjustible.
On the RIGHT side of OFF everything is WARM ans IS adjustible.
-Hope I've helped you...
Old Jan 3, 2013 | 08:28 AM
trekbasso's Avatar
trekbasso
Thanks Supercab. I am thinking of adding a vacuum switch, put it back to stock when I want more control. Otherwise I guess it is okay.
Old Jan 3, 2013 | 08:39 AM
mueckster's Avatar
mueckster
I have an electrically operated vacuum switch that I was going to use for that same purpose. I ended up scrapping that idea. If you make the gtg this weekend I can bring it, if you're interested. It could be tied into the a/c compressor control of the switch and use a full time vacuum source. That way it only closes the heater valve when the a/c is on.
Old Jan 3, 2013 | 08:43 AM
trekbasso's Avatar
trekbasso
Not a bad idea, to at least look at it. I was thinking of a simple off/on, put the vacuum source back to stock when I want different control.
Thanks Roland.
Old Jan 3, 2013 | 02:20 PM
jeffreyt's Avatar
jeffreyt
I still haven't quite understood the need for this mod/fix. Every one of these trucks I've been in has colder air than any other (minus a Mazda protege I had in highschool that blew ice out the vent). Have I just had good luck, or am I missing something?
I understand how the lines are ran and how the door blends and all, but I can rarely run the temp **** all the way left as it is. Maybe I'm just acclimated to the heat lol
Old Jan 3, 2013 | 03:19 PM
trekbasso's Avatar
trekbasso
Basically it is up to personal preference. All other vehicles I have seen have some sort of heater control valve in the engine comp, cutting off the flow of coolant. I like running vent a lot, and before the air felt warm when it was 65-70 outside. This is because the air is picking heat up from the heater core, because hot coolant is always in the core. Cut off the heat, core cools off, cooler vent temp., and that means colder ac also.
Old Jan 3, 2013 | 03:26 PM
jeffreyt's Avatar
jeffreyt
So it's more for using vent control with the compressor off, there is more benefit. That makes since. I never take it off max or AC unless its on defrost, which all utilize the compressor. Since I don't use the coldest setting normally, I wouldn't see much benefit.
Thanks for explaining that Tom
Old Jan 3, 2013 | 03:40 PM
trekbasso's Avatar
trekbasso
Well, I think so. One version uses the white vacuum line, which I believe works only on max air. But I was interested in vent being cooler also.
gooldg
Jul 12, 2016 08:55 PM
duphofff
Aug 12, 2015 02:31 PM
Bubba Jones
1978 - 1996 Big Bronco
24
Mar 19, 2014 10:55 PM
78bigunns
Jul 10, 2011 09:28 PM
Dad's Truck
Apr 27, 2005 08:13 PM
