Bad injector?
Old Dec 31, 2012 | 10:53 PM
Mehrmannfarms's Avatar
Mehrmannfarms
Bad injector?
Had to replace Iap sensor this weekend. Once I got the truck running I noticed that the ruck would shake once it hit overdrive. If you raise rpm it goes away. It is also a little slow starting and rough at idle. Just wondering if a weak injector will miss out and cause the truck to shake in that load and rpm scenario
Old Jan 1, 2013 | 06:22 AM
mustang_309's Avatar
mustang_309
What year is your truck? Do you have gauges that can read live data? If not you need gauges to diagnose your truck. Scan gauge II, Edge insight or smartphone apps Torque or Dashboss are popular ones.
Old Jan 1, 2013 | 06:26 AM
Papa Tiger's Avatar
Papa Tiger
Do U have any codes?
Old Jan 1, 2013 | 12:31 PM
Mehrmannfarms
No codes I double checked all of my connectors since it didn't run this bad before the icp sensor swap. Can a new icp sensor magnify a bad injector or in same sense a bad icp sensor mask a bad injector by raising injection pressure
Old Jan 1, 2013 | 12:43 PM
Papa Tiger's Avatar
Papa Tiger
Do a little more of the "little things" first. Reset the puter and recheck the Air intake.
Mdennis0_8
20
Mar 8, 2020 05:42 PM
cookingguy
Mar 2, 2018 10:54 AM
Tugly
Sep 20, 2015 09:00 PM
74broncosport
2004 - 2008 F150
Jun 13, 2009 07:45 AM
gomfrddy
Jan 21, 2007 06:38 PM
