Do I have the BLEND DOOR Problem??
Old May 26, 2003 | 03:35 PM
kev100's Avatar
kev100
Folks,
Have a 98 Ford Exp. XLT
I noticed recently that when the flow selector was at "11 'oclock" (through front dash panels only), it will only blow hot air....no matter where the temperature selector is set.
If the selector is on AC or Max/AC is WILL blow cool (thank goodness). But when on any other flow setting (panel, defrost, floor, combo, etc) it will only blow hot.
Is this the Blend Door issue?
THANKS!
Old May 27, 2003 | 03:10 PM
kev100's Avatar
kev100
One other thing.....I noticed that a few days before this started, switching from Hot to Cold took a little longer. When I turned the temperature switch...it seemed to be "straining" as it slowly switched from Hot to Cold.
Any advice appreciated. THANKS!
Old May 27, 2003 | 10:47 PM
WillieTD's Avatar
WillieTD
Sounds like the classic blend door problem.
Old May 29, 2003 | 12:16 PM
c96drumm's Avatar
c96drumm
Sounds like it.
Another blend door fix
Here's how I fixed my blend door.
The recess in the blend door that the actuator motor shaft engages is deeper than the shaft reaches. My blend door still had some undamaged hole depth left in it. So I made an extension for the actuator shaft so it could reach the undamaged part of the hole and move the door.
This extension is made from 3/8" aluminum rod, 15/32" long. I drilled and tapped the center of the end of it to take a piece of 2-56 threaded rod. A bit bigger would be better, but that's what I had on hand. Then I filed and belt sanded the extension to match the "D" shape of the actuator shaft. It has to taper down quite a bit to fit into the door hole, which has a taper. You can see this with a mirror.
To keep the extension from rotating out of alignment, I made matching shallow razor saw cuts in the ends of the shaft and extension and upon assembly, inserted a small piece of thin sheet metal in the cuts to lock them into alignment.
I failed to measure the length of the threaded rod I used. I just made it long enough to stick out the top of the actuator shaft (it's hollow) far enough to get a washer and 2 nuts on it. (jamnut)
I used loctite where the rod screws into the extension and epoxy where the shaft and extension join to keep that little piece of sheetmetal in place and for additional strength.
I'm hoping this will make a permanent repair because the material at the bottom of the hole is thicker than at the top, so maybe it won't break.
See my gallery for pictures. Sorry the pictures are so bad. My camera won't focus very close.
If any of this isn't clear, say so and I will try to clarify it.
__________________
Old Jun 4, 2003 | 07:11 PM
Hellbender's Avatar
Hellbender
I also had this problem and I fixed it be shaping a replacement piece to help Trap actuator motor shaft in the blend door. I explain my fix to Dave's post for heater issues. Mine was a '97. Almost anything is better then the thought of replacing the whole heater box which includes dash removal and AC removal under the hood
97ExpGuy
Jun 24, 2014 07:01 PM
fnx4wheeler
Sep 19, 2013 01:10 PM
kovi
Aug 26, 2013 02:30 PM
1great40
Jun 10, 2013 05:34 AM
dlueder
Aug 15, 2006 12:06 PM
