5.4 running lean
Old Aug 29, 2022 | 08:24 PM
Beechkid's Avatar
Beechkid
Originally Posted by projectSHO89
O2 sensor very rarely cause "lean" codes. Don't shoot the messenger(s).
So much for the Ford diagnostic tree- and don't shoot this messenger either. GRIN!
Old Aug 29, 2022 | 08:43 PM
projectSHO89's Avatar
projectSHO89
And which step in the pinpoint might that be? You've been around here for twenty years. How many threads regarding "lean" codes were closed out reporting that two new O2 sensors actually solved the "lean" codes?
For more insight, check out TSB 01-9-7 which includes this excerpt:
F4.) Tips Related to the Fuel System Monitor
  1. HO2S sensors are not likely to be the cause of adaptive DTCs P0171, P0172, P0174, P0175: Most warranty-returned HO2S sensors (replaced for these DTCs) are found to function normally. Additional related DTCs will normally be present if there is a concern with the HO2S sensors. Do not replace an HO2S sensor unless verified through pinpoint diagnostic tests found in the PC/ED Service Manual.
Old Aug 29, 2022 | 10:26 PM
Beechkid's Avatar
Beechkid
t:
Lets start with 1) Check inputs.... the TSB states do not start replacing unless you use pinpoint tests to verify inputs (paraphrasing)..... I at no time advised to replace the O2 sensors but to look at them IE check them out.....
2) be respectful
Old Mar 30, 2023 | 06:19 PM
MikesF1's Avatar
MikesF1
5th Gear
2) be respectful
What do you mean check inputs?
Mike,
Old Mar 31, 2023 | 03:08 PM
Beechkid's Avatar
Beechkid
Mike,
Check the signal (voltage) to/from the ECM/O2 sensors and then test the O2 sensors themselves (voltage) when they are heated/cooled
dewalters8886
Mar 20, 2017 04:29 PM
bren_tx
1997 - 2003 F150
Sep 13, 2016 10:10 PM
caprisecca
Jul 2, 2014 05:37 AM
ray299
May 25, 2012 05:10 PM
johare
1983 - 2012 Ranger & B-Series
Mar 6, 2006 05:46 PM
