WTF is this
Old Dec 31, 2012 | 08:28 PM
cbr600rx7's Avatar
cbr600rx7
WTF is this
Ok guys i ont know what this is. There is white milky substance on the inside of the valve covers. But the oil is clean and so is the antifreez. Any idea's.
Old Dec 31, 2012 | 08:34 PM
rodneywar's Avatar
rodneywar
Condensation inside the block a little water mixed with oil don't know what caused it but have seen a few trucks recently with the same problem it is possible the humidity is affecting it
Old Dec 31, 2012 | 08:37 PM
cbr600rx7's Avatar
cbr600rx7
Strange i have never seen it before. Scared me at first.
Old Dec 31, 2012 | 08:53 PM
richdawg's Avatar
richdawg
WAG----- a lot of short trips in warmer very humid weather, moisture collects and mixes with oil. Then a long drive, engine working hard causing milky oil to vaporize leaving milky stuff inside valve covers IDK This may have to be repeated for some time.
Good luck with that hope it doesn't continue
Old Dec 31, 2012 | 09:01 PM
cbr600rx7's Avatar
cbr600rx7
Hmmm. The truck did sit for 4 years. I of course changed the oil. 2 times in fact before taking it out on its first long drive and that was a few days ago.
Old Dec 31, 2012 | 11:11 PM
richdawg's Avatar
richdawg
More thinking about that, moisture in the oil would most likely raise hell with the hpop and injectors causing it to run really bad. I think I would clean it off the best you can, keep an eye on the oil, maybe have the oil analyzed.
Old Jan 1, 2013 | 05:23 AM
427 fordman's Avatar
427 fordman
As long as your water level isn't going down, its more than likely condensation. That is quite ugly, keep an eye on it.
Old Jan 1, 2013 | 06:17 AM
Brant Bowrifle's Avatar
Brant Bowrifle
I've seen this happen in cold weather from normal blow by. It will show up in higher quantities with excessive blow by. It's caused by a chemical reaction with water molecules. But seeing this vehicle has sat for a while and there are multiple causes, hopefully it works itself out.
Old Jan 1, 2013 | 08:17 AM
F350-6's Avatar
F350-6
Kind of changing the subject a little, but I'd say it's time to re-think your air filter strategy. Looks like a good time to take the intake tube off, clean it, and see how bad your turbo wheel is dusted.
Old Jan 1, 2013 | 09:19 AM
cbr600rx7's Avatar
cbr600rx7
What are you talking about. I removed the K&N filter a day ago since the truck is sitting in the shop. I ordered a RDP 6637 Filter Kit. I also took a few pics of the turbo a few days ago. (the factory air box on the truck had been trashed) I ran the K&N filter for about 300 miles so i could get the truck back to NC to work on it (better then no filter) The wheel does have some saw bladiing but is not horrible and has very little play.
Old Jan 1, 2013 | 10:25 AM
Talyn's Avatar
Talyn
Good ole water.
This gonna sound stupid.
Go get a full oil change and a can of sea foam.
Run the sea foam for 100-300 miles or something and then change your oil.
The seafoam will take the water out of the oil.
Old Jan 1, 2013 | 11:48 AM
Action4478's Avatar
Action4478
Given that its white , I would clean the covers & get the engine hot . May need a new thermostat ...
Old Jan 1, 2013 | 11:50 AM
Talyn's Avatar
Talyn
I need a new t-stat myself. the parts store one didn't even last a year.
Old Jan 1, 2013 | 12:18 PM
srteach's Avatar
srteach
That white stuff is water from the air (condensate) mixing with chemicals in the oil and then separating from the oil. The additive package from the oil is getting depleted.
Do what Talyn said above with the Sea Foam treatment.
The condensate appears in high humidity environments when engines don't get heated up for enough time in a single session. Your engine sitting for an extended time collects moisture from the air in the oil. When you then run the engine, the moisture need heat and time to boil out of the oil. Looks like you have too much moisture in the oil to boil out. Sea Foam will bond with the moisture over time (or miles) and keep it in the oil. Then when you change the oil, it also removes the moisture.
Old Jan 1, 2013 | 12:21 PM
Talyn's Avatar
Talyn
Sea foam really needs to pay me or send me free product for as much as I pimp it.
