need help finding a driveshaft
Old Dec 31, 2012 | 07:00 PM
jpeckham's Avatar
jpeckham
i have an 88 ranger 4wd with the 2.9 5sp. im looking for the rear driveshaft but cant find them anywhere with this one being a 2 piece shaft. any ideas from anyone here is helpful. thank you. the boneyard dont have anything this old anymore and cant order them.
Old Jan 1, 2013 | 08:29 AM
pawpaw's Avatar
pawpaw
If no luck here, you might inquire on the FTE driveline forum Clutch, Transmission, Differential, Axle & Transfer Case - Ford Truck Enthusiasts Forums, or post what you need on the "Want To Buy" forum just below on the FTE forums index page.
Old Jan 1, 2013 | 10:54 AM
slc10844's Avatar
slc10844
Check ebay. Someone is always selling driveshafts there, both used and reconditioned. A shop that specializes in driveshafts can make one if necessary.
Old Jan 1, 2013 | 10:57 AM
MikeB 88's Avatar
MikeB 88
Since the salvage yards don't have one, have you tried LMC trucks or Rock Auto?
Old Jan 1, 2013 | 01:14 PM
jpeckham's Avatar
jpeckham
i tried lmc but the only one they are showing is a 1 piece and the one that looks like a 2 piece is a completely different setup
just checked rock auto, they are only a 1 piece also unless im missing something
Old Jan 1, 2013 | 01:29 PM
85e150's Avatar
85e150
Do you have your old one? If the u joints are serviceable, it can be retubed.
This outfit can probably come up with something:
Ford Driveshaft | Indy Driveshafts
IMO, you are going to have a tough time finding a used OEM shaft. While a bit more money, a new or retubed job is straight and balanced, something you can't be sure of with a junkyard shaft.
Old Jan 1, 2013 | 01:43 PM
jpeckham's Avatar
jpeckham
mainly it needs new yolks
Old Jan 1, 2013 | 01:52 PM
Beechkid's Avatar
Beechkid
They are not that expensive & any local driveline shop should be able to build one for you in just a couple of hours.
Old Jan 1, 2013 | 03:18 PM
slc10844's Avatar
slc10844
I have a 87 2wd and a Ford factory repair manual. The driveshaft has two sections with the carrier bearing at the rear of the front section. The manual refers to the front section as an intermediate shaft and the rear section as the driveshaft. I was looking for a replaement driveshaft expecting both as an assembly but everyone only showed the rear section.
Old Jan 1, 2013 | 03:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
mainly it needs new yokes
Unless bought used, yokes were not furnished with driveshafts as original, were only sold by themselves. Rear yoke (Ford basic part number 4851) known as a companion flange as it's located on rear end.
Two piece driveshaft has front and center yokes (basic number 4841). Is your Ranger a Regular Cab w/a 7' bed, or a Super Cab?
Old Jan 1, 2013 | 04:19 PM
jpeckham's Avatar
jpeckham
extended cab
i know what you mean, im having the same problem. everyone only shows the rear shaft and i cant find the intermediate shaft. whenever i do a search for it, all i find is the intermediate power steering shaft
also the front of the first section (intermediate shaft) has a "companion flange" just like the one on the end of the driveshaft connecting to the rear end
Old Jan 1, 2013 | 04:49 PM
slc10844's Avatar
slc10844
Does your front shaft have a rubber coupling between the yoke and the shaft? I made a mistake, they call the front shaft a coupling shaft not an intermediate shaft.
Old Jan 1, 2013 | 06:15 PM
jpeckham's Avatar
jpeckham
im assuming your talking about the carrier bearing? yes it does.
if your talking about the rubber on the top end of the long shaft yes it has that too since its a slip shaft or whatever its called
Old Jan 1, 2013 | 06:42 PM
slc10844's Avatar
slc10844
Mine has a large rubber dounut between the transmisson slip yoke and the shaft. No u-joint.
Old Jan 1, 2013 | 06:54 PM
jpeckham's Avatar
jpeckham
mine dont. i have 3 u-joints. one on the top of the short shaft with a flat base that connects to the tranny/transfer case (cant remember at moment), another between both shafts and finally on the end of the long shaft that connects to the rear end also with the flat base
