need new brakes
Never tried Brakemotive...
Cryo treated rotors (Powerslots, ART, etc) aren't cheap. But they are excellent rotors.
Google search cryo treated Powerslots and sift through the results to find the cheapest place.
Stewart
Both companies (DC & ART) purchase the highest grade rotors made, laser mic them for quality, scrap the ones that are out of spec and cryogenically treat the good ones which are now as strong as stainless. They will also slot and cross drill the rotors for you. DC's service, price and quality are excellent as well.
For street use, slotted/drilled rotors are just “cheese-graters” for the brake pads IMHO, because unless you are involved in true racing conditions, the brake linings do not produce the gases which slotted/drilled rotors are designed to relive. In some cases, brake testing indicated reduce brake efficiency in street-based operations using slotted/drilled rotors when equal comparisons were made. The staff can speak to you as well regarding those options, but I am very satisfied with the performance & wear of these products.
With regards to brakes & brake linings in general,
Ceramics: They are good but do not develop any more friction than good quality OEM linings
Performance Friction & Hawk: Good braking, increased friction but very dirty compared to OEM- Hawk & EBC will no longer release their CE spec's...basically you are buying blind IMHO (ie. running off their PR materials and not engineering specs)
Wagner & Raybestos: a line of products that is 100% marketing and mfg from very low quality/inexpensive and/or imported products with the mfg's not providing any back-up or support on product failures (and I mean real ugly spontaneous, catestropihic failures)
VelveTouch lining- Used for many decades and was the original lining used in all Shelby Mustangs in the 60’s (I personally have used the Velvetouch lining since 1960’s until brake lining production ceased in 1986), then switched to Carbo. Wellman has been the builder of braking linings for all of the Formula 1 race teams for more than 30 years and VT is now available again but in limited applications.
CarboTech Engineering lining, which I have used for about 25+ years and been very happy on multiple full size (V8) cars and trucks. This particular lining has a high friction co-efficient, excellent pedal feel, wears (typically 50,000 to 75,000 miles before replacement is required) and produces less dust than OEM linings.
I highly recommend speaking to them by phone for linings that would be best for your application. Fyi- braking co-efficient is what identifies the bite rating of the linings- you want the CE to be no less than that of the OEM.....this will drive most e-base distributors & big box store "experts" right out of their mind because they either cannot verify this info or you will find the spec is less than oem. IMHO, i would look for a CE that is .49 or greater.
I looked at DC's site and they look good, I'm just not sure if I'd benefit as I wont cover the miles?
