5.4 intermittent coil issue
Old Dec 31, 2012 | 01:42 PM
Bsmith153's Avatar
Bsmith153
I just bought a 2005 F150 with a 5.4. It started with a rough idle, then the check engine light came on. The code scanner said misfire #3 cylinder. Replaced the coil, ran fine for ten miles , same problem same code. Put spark plug in old coil no spark, swapped with new coil, no spark, tried old coil again, spark. Truck ran good for about 5miles started with rough idle again. Seems like it fires and misfires whenever it wants too. Looking for ideas? Oh yeah truck has 115k on it!
Old Dec 31, 2012 | 07:46 PM
LxMan1's Avatar
LxMan1
I would inspect the coil connector and wiring harness. Perhaps a rodent has eaten thru a wire or their is a bad connection somewhere.
Old Jan 2, 2013 | 05:19 AM
JWA's Avatar
JWA
+1 on this ^^^ ! Had ths same thing happen about a week after installing new Granatelli COP's---I was bummed. Discovered the locking tabs on the harness connector had been damaged (perhaps by previous owner?) and it decided to stop making full contact. NAPA EC259 solved this problem, about $20 each sorry to say.
With engine running jostle each COP's connector, looking for frayed wires etc. the misfire should come and go as you manipulate the wiring---might be very easily seen at that point.
Oddly enough though that #3 plug even on my E250 with 5.4 has been problematic on two different vehicles so far---curious this is!
HTH
Old Jan 4, 2013 | 08:17 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
Different engine, but same principal. See if this helps: https://www.ford-trucks.com/forums/1...il-wiring.html
handell35
2004 - 2008 F150
Apr 29, 2013 02:37 PM
stuemany
Feb 19, 2013 05:34 PM
fordhacker150
1997 - 2003 F150
Apr 14, 2009 04:22 PM
flatline911
Jan 28, 2008 10:53 AM
MAINTAINER
Modular V8 (4.6L, 5.4L)
Jan 4, 2004 10:34 PM
